craftsman 315.269210 depth adjustment - Router Forums
post #1 of 4 (permalink) Old 12-04-2010, 04:25 PM Thread Starter
Default craftsman 315.269210 depth adjustment
This was a good router. I haven't used it quite a while. The depth adjustment doesn't turn anymore! Anyone else have this problem?
BobNS is offline
post #2 of 4 (permalink) Old 12-04-2010, 05:16 PM
First Name: del
i would take it apart and do a good cleaning and oiling . If something is stuck and won't come loose with a good force. Don't break anything go get some PB blaster and spray the out side item's Don't spray inside motor . good luck
del schisler
port st. lucie, florida
del schisler is offline
post #3 of 4 (permalink) Old 12-04-2010, 05:45 PM
Hi Bob - Welcome to the forum
Those old Craftsman things are a PIA. Probably had some sawdust in the adjustment mechanism that solidified on you. Might be able to take it apart and clean it up, PB Blaster, WD-40 or similar might loosen it up enough to do that. Here's a link to a parts explode that may help:
http://www.searspartsdirect.com/part...&prst=&shdMod=
John Schaben
jschaben is offline
post #4 of 4 (permalink) Old 12-05-2010, 12:43 AM
xplorx4's Avatar
First Name: Jerry
Greetings Bob and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
Depth Adjustment Problems Crftsmn Router dosorenso General Routing 4 07-29-2012 05:16 PM
trouble adjusting the depth of my Craftsman router JohnnyB60 General Routing 7 06-19-2009 07:13 PM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 04:30 PM
Craftsman 315.175040 Router Depth Adjustment gloftis Starting Off 3 06-16-2007 02:55 PM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 02:20 PM
