Selecting a router - Router Forums
post #1 of 7 (permalink) Old 12-10-2010, 12:15 AM Thread Starter
Question Selecting a router
Hello,
I am new to woodworking. I am planning on buying a router to eventually get enough practice before I start making my own kitchen cupboards for my home.
I did a lot of reading up and it seems that all signs indicate that Festool Routers provide the best value for your money when it comes to quality and durability.
I don't want to throw money at an overkill (it's for personal use), but at the same time I don't want to buy something that will fall apart after 1 year (because I dont want to spend the money twice). That being said, I have been looking at the Festool OF 2200 EB Router because it seems like a workhorse that will stick with me through thick and thin. However, the price is significantly higher than everything else I see.
So my goal is simple, learn routing and get a machine that is easy on the learning curve and one that is durable enough for me to make my own kitchen re-design and maybe a few other around the house projects.
Can someone recommend a router for me and a suitable table? Or am I stuck with the decision to buy a Festool OF 2200 EB Router?
Thanks for your help folks.
DW
DAWILLIAMS is offline
post #2 of 7 (permalink) Old 12-10-2010, 01:51 AM
Ralph Barker's Avatar
First Name: Ralph
Festool makes exceptional, well-engineered tools. I have a couple of their tools, but not their router. The problem is, you pay about 2x the price of other quality tools for Festool.
I'd suggest you look at less-expensive alternatives for your "starter" router. Craftsman makes a decent package with both fixed and plunge bases, for around $100, if I remember correctly. If you want to go a little higher on the quality scale, Porter Cable, Bosch, and several others are good alternatives. You'll likely find that you're still using any of these brands years from now.
Although some use the same router for both hand-held work and in a table, I prefer a lighter model (PC 690series in my case) for hand-held work, and a larger, 3 1/4hp model in the table, since I use large-diameter bits frequently.
- Ralph
Ralph Barker is offline
post #3 of 7 (permalink) Old 12-10-2010, 07:19 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
The following appeared in the Trend Inprofile magazine in 1997 and seemed worth reprinting:
Routing encompasses a wide range of skills, not just in handling the router itself, but in using it to its best advantage in conjunction with various, guides, jigs and other ‘routing devices’, as well as the extensive range of router cutters now available. Routing is also about innovation in both the methods and applications to which the router is applied and in the aesthetic and technical design that it is used to create.
The Router
Most woodworkers turning to routing have some idea and experience of working with power tools.
Most householders will have occasionally used a jigsaw or electric drill and will know that power tools come in a range of power ratings and capacities - the more power you have, the faster and harder you can go about the job - well that’s the theory anyway!
However, as if you are buying a new car, computer or washing machine, you will still want to know just what to buy to suit you and your pocket. Accordingly, the questions facing the newcomer to routing are most likely to be:
How much power do I need?,
What collet size do I need?,
Do I need variable speed?,
Do I need to buy lots of accessories?,
Do I need to buy lots of cutters?
Self Assessment!
How much power? - This depends on the type of work that you intend to use the router for.
If you are cutting dolls house mouldings or trimming veneers or laminates, there is little point in buying a heavy duty router. It will be too heavy and clumsy for the purpose. Conversely, if you are making doors and window frames, you would not be able to remove
enough material efficiently without overloading the motor. This would cause the cutting speed to drop, resulting in a poor finish and possible premature burn-out of the motor and bearings.
Collet Capacity
For many applications the strength of a cutter often depends on the diameter of the cutter shank. The thicker the cutter shank, the more wood you can remove and the deeper you can cut on any one pass, with less risk of the cutter flexing excessively or breaking.
Light duty routers are generally supplied with 6.5mm (1/4”) collets although some models can be fitted with an optional 8mm collet. The introduction of 8mm shanks has allowed many of the larger diameter cutters to be used in light duty routers, although particular care must be taken when using them and any manufacturers recommendations concerning cutting speed and depth of cut must be closely observed.
Most medium and heavy duty routers can be fitted with alternative diameter collets of 6.35mm (1/4”), 9.5mm (3/8”), 12.7mm (1/2”) and 8mm diameter, although most are supplied with only 1/4 inch or both 1/4 and 1/2 inch collets. Alternative size collets are available for most makes and models of router. Do remember that small diameter cutter shanks will flex more, with a greater risk of breakage under the increased load from a heavy duty router. Remember that small diameter cutter shanks will flex more, with a greater risk of breakage under the increased load from a heavy duty router.
Router Power
(746 watts = 1 HP )
Light Duty Routers
400-750 Watts
Medium Duty
750-1200 Watts
Heavy Duty
1200 and above
Speed & Variable Speed
Router spindle speeds are generally given as o-load speeds, that is the speed that the motor spindle is rotating at before the cutter enters the wood. This is generally between 8,000 and 30,000 RPM depending on the power of the router. Light duty routers will have a higher no-load speed to help compensate for their lower power. Most routing operations using cutters up to 25mm diameter, should be carried out at the maximum router speed to achieve optimum cutting efficiency.
Operations involving the use of cutters over 50mm diameter should be carried out at speeds of between 12,000 and 16,000 rpm. Variable speed routers with full wave, load compensated electronics, tend to run smoother and possibly quieter than single speed machines, resulting in reduced bearing wear and eliminating the initial jolt on start-up.
They also accommodate the use of large diameter cutters at their recommended safe speed. Aluminium and plastics require routing at lower speeds to reduce overheating or melting, preventing problems such as weld-back, whereby molten waste material re-forms
within the cut, or the fusion of waste particles to the cutter.
Which Accessories?
The few guides and accessories supplied with the router allow you to carry out various basic cutting operations such as edge trimming, moulding, and template work. However, to increase the versatility of your router it is worth considering adding further accessories toyour routing workshop.
istracpsboss is offline
post #4 of 7 (permalink) Old 12-10-2010, 08:09 AM
First Name: del
I didn't read other post's yet. But why dont you save lot's of your money and buy a bosch 1617 or a pc 690 which i have of each. They are very good router's and won't let you down. Me i wouldn't spend that much on the festool. Just because they cost about 2X the money don't make them that much better?? This is my 2 cent's
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 7 (permalink) Old 12-10-2010, 09:28 PM Thread Starter
Thanks Ralph and Del. I will look into your recommendation. I see a lot of cheap and affordable stuff. But I was asking to see what everyone's take was on price versus quality.
Ralph...does the 3 1/4 hp model run any risk of tripping a household breaker? Or is that bigger one safe for use in my basement?
Can you recommend a good table?
post #6 of 7 (permalink) Old 12-11-2010, 01:05 AM
First Name: Ralph
It's a 15 amp, so it will run on a standard 20 amp household breaker. I wouldn't have a heater plugged into the same circuit, though.
As to tables, think about making your own, based around the plate or lift of your choice. If you want to buy a commercially-made table, the guys here like Oak Park. My previous table was a Rockler top-only that I put on a large WorkMate. The BenchDog tables look well-made, too. (Rockler now owns BenchDog, I believe.)
- Ralph
post #7 of 7 (permalink) Old 12-11-2010, 02:45 AM
RustyW's Avatar
First Name: Rusty
My house has all 15 amp circuits with the garage circuit sharing half the kitchen, and one wall of living room. I use the Hitachi M12V2 in my table. It's rated at 3.25 Hp, 15 amps, and has never tripped the breaker. But twice while ripping maple on the table saw(1.5 HP, 15 amp) the breaker has tripped when the microwave gets used at the same time. Maybe I've just been lucky and no ones decided they needed popcorn while I'm routing.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 06:40 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 11:01 PM
selecting table-mounted router mike turner General Routing 10 08-01-2010 01:11 AM
