Proper Speed for Routing - Router Forums
post #1 of 7 (permalink) Old 12-14-2010, 09:12 PM Thread Starter
metzgeri's Avatar
First Name: Tim
Default Proper Speed for Routing
How does one determine the proper speed to route at on a variable speed router?
What factors should I take into consideration and how should I use them to determine speed (ie wood type, bit diameter, depth of cut, phase of the moon, roll of the dice... )?
Is there a chart that correlates router speed to bit diameter (or something like that)?
Tim
metzgeri is offline
post #2 of 7 (permalink) Old 12-14-2010, 10:02 PM
First Name: Paul
Dont forget to live life for fear of death grasp each day and live it to it full otherwise it is pointless.
newwoodworker is offline
post #3 of 7 (permalink) Old 12-15-2010, 10:38 AM Thread Starter
metzgeri's Avatar
First Name: Tim
Great chart!! Thanks!!
I guess there are no concerns with speed versus hard/soft wood....as long as it doesn't burn, huh???
Tim
Words to be raised by: "I am I plus my circumstances"
Words to Live by: "Proper Planning Prevents Piss Poor Performance"
Words to die by: "Arbeit Macht Frei"
metzgeri is offline
post #4 of 7 (permalink) Old 12-15-2010, 11:11 AM
Tim
Hi Tim - I don't recall seeing any charts referencing hard vs soft wood. However, with hard woods you may need to feed a bit slower and conseequently need to slow it down a bit, sort of a gut feel thing. There are several charts out there and all seem to be just a bit different but any of them give a good starting point and then I will adjust from there until it "sounds right". MLCS has one on there website that also has recommendations concerning the length of the bit also.
John Schaben
jschaben is offline
post #5 of 7 (permalink) Old 12-22-2010, 12:21 PM
First Name: Randy
Default Is it okay to work at the slowest speed?
Hi all,
I've had the same question too.
I see in the image above it says "Slower operation will often produce a cleaner cut with less burning and tear out while extending the life of the bit."
Other than the time it takes for a cut, is there any reason you couldn't leave the router on it's slowest speed?
In general, if the bit is slowed down should your feed rate slow down?
Thanks from another newbie!
Randy
RandyMorter is offline
post #6 of 7 (permalink) Old 12-23-2010, 12:17 AM
Welcome to the RWS forum
post #7 of 7 (permalink) Old 12-23-2010, 09:21 AM
First Name: Justin
Great chart, thanks for the tip. This forum is great!
rucraz2 is offline
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 11:38 AM
Modulated speed router problem. seanburns General Routing 6 08-19-2013 09:20 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 05:10 PM
True Router Speed bobj3 General Routing 6 09-07-2010 12:23 PM
adding a speed controller to a single speed router Sawatzky Table-mounted Routing 5 01-24-2009 09:49 AM
