Freud FT3000 - Router Forums
post #1 of 5 (permalink) Old 12-20-2010, 07:36 PM Thread Starter
Default Freud FT3000
Hello, new to forum, great resource.
I bought a Freud FT3000 to use in my router table. I looked at many routers, but this one met all my needs (above table adjustments, single wrench bit removal, 3.25 hp).
So having said that, am I supposed to remove the plunge spring from the router before I install it? Many other plunge routers (I.E. Triton) require you to do so. Would it make raising and lowering the router easier?
Thanks in advance for any responses.
Steve
steveb624 is offline
post #2 of 5 (permalink) Old 12-22-2010, 12:56 AM
First Name: Colin
Hi Steve, you can leave the springs in or take them out. I have the same router and I leave mine in for 2 reasons.
#1 - From time to time I do have a need to use this router out of the table (part of the reason I selected it)
#2 - I actually prefer the extra firmness of having the springs in, even when the router is in the table.
Yes it is a wee bit easier to move the router up and down with the springs out but I have never found it a problem leaving them in.
Colin
Collett is offline
post #3 of 5 (permalink) Old 12-22-2010, 10:27 AM
Steve
HI Steve, I'm leaving them in mine. With the lift it becomes a non-issue, at least to me. I am going to make some kind of crank or large knob to increase the mechanical advantage of raising and lowering the height.
John Schaben
jschaben is offline
post #4 of 5 (permalink) Old 12-23-2010, 12:15 AM
Welcome to the RWS forum
post #5 of 5 (permalink) Old 12-24-2010, 08:16 PM Thread Starter
Thanks for the response. Have a great holiday.
Steve
Freud FT3000 VCE Table Insert Issue andyk Table-mounted Routing 13 01-05-2011 07:11 AM
Freud FT3000 question steveb624 New Member Introductions 1 12-13-2010 03:43 AM
Freud Router stjimm General Routing 1 01-03-2009 12:04 PM
Freud Routers Bill A Tools and Woodworking 2 11-26-2007 08:47 AM
Freud FT3000 collet? ezatt Starting Off 4 01-19-2007 04:54 PM
