wainscoting - Router Forums
post #1 of 6 (permalink) Old 12-22-2010, 01:03 PM Thread Starter
Default wainscoting
looking to do wainscoting in a couple rooms so looks like doing it from scratch will end up less $$$$ then getting kits, my question is i'm looking at vertical panel and rail and stile bit sets and most are for doors and 3/4" to 1" thick stock but most wainscoting is 5/8" stock, i'm looking to build it out of MDF since i'll be painting it.
so can i use the larger bits or do they make a set for 5/8" stock
RICK-SWAMPER is offline
post #2 of 6 (permalink) Old 12-22-2010, 01:17 PM
Hi
Check out the link below and the video.
Wainscoting Router Bit Sets Home Improvement Project
post #3 of 6 (permalink) Old 12-22-2010, 01:20 PM
Hi Rick, welcome to the forum
Try this link:
MLCS Rail and Stile Carbide Tipped Router Bits 2
You need to scroll down a bit to find the "minuature" rail and stile bits.
Why not just cut your rails and stiles from 3/4" MDF though? Likely cheaper than a special bit set unless you have other uses for it. Just a random thought from a wandering mind
John Schaben
jschaben is offline
post #4 of 6 (permalink) Old 12-22-2010, 01:42 PM Thread Starter
Honestly I was going with 5/8 since that seems like what I see everywhere that people use and Im just trying to figure out what bits I need, seems like the larger bits put a slot in the rails for the panel and the smaller bits put a rabbit on the back side, and if I go with the larger set that put the grove in the rails wouldnt the panel stick out past the rails ? Im sure this is a dumb question but figured I ask
post #5 of 6 (permalink) Old 12-22-2010, 03:42 PM
Hi Rick, you can undercut the panels, or use 1/2 or 1/4" panels, 1/4" for flat panel or beadboard.
John Schaben
jschaben is offline
post #6 of 6 (permalink) Old 12-22-2010, 06:29 PM
AP3D's Avatar
First Name: Arnold
The only dumb question is the one that was not asked. If you have a question, there is a good chance others need the answer also.
Arnold
AP3D is offline
wainscoting, plung cutting johnschiano1955 New Member Introductions 3 02-26-2010 03:15 PM
Wainscoting Project doglegleft Project Plans and How To 2 11-22-2009 10:20 PM
Wainscoting Raised Panel jerry45 New Member Introductions 3 08-11-2009 09:56 PM
MDF raised pannel wainscoting MaintenanceWork Table-mounted Routing 28 03-04-2009 07:38 PM
Raised panel wainscoting digger 123 Project Plans and How To 6 11-01-2008 04:29 PM
