Router crafter/ router lathe candle stick - Router Forums
post #1 of 15 (permalink) Old 12-24-2010, 04:13 PM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default Router crafter/ router lathe candle stick
Well I mentioned earlier that i was hoping to incorporate this tool into some Christmas gifts. I have attached a few photos, it was a chore. One of my boys wanted to make a candle stick holder with this unit so I bought a chunk of maple and out to the barn we went. First I discovered I don't have the right bit so we tried a compromise, (won't do that again), I started with a V bit and wanted to come along behind with a round over bit. Nothing doing, you can see some off the errors in the photos. I had difficulty lining up centers, too much slop in the tool itself, some of this was from the wood coming loose from its moorings, and some from the way the carriage would jerk along the tubes. And never, NEVER, under any circumstances try to back the router up. This causes the router to climb out of the flute and ruin the piece. Unless your 14 and you think, "Hey, this is cool, I can live with those imperfections!" Sure, but can mom?
Next we moved to the lathe and tried turning a base for the candle stick. I bought both of these tools used. The lathe has a few issues, but I think by summers warmer weather I will have over come them.
Noah is quite proud of his work, I was very happy to have him out in the shop with me, and honestly, I know mom will love it, with all its little mistakes!
It seems the pictures are not in order, but you'll figure it out.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 15 (permalink) Old 12-24-2010, 04:38 PM
Bob N's Avatar
First Name: Bob
Hi Jack,
That's some darn fancy woodworking for a young fellow (even an older one too)
I know Mom will be very proud of it.
Bob N is offline
post #3 of 15 (permalink) Old 12-24-2010, 04:48 PM
Hi Jack,
Sounds like you had a 'man's' day in the shop.
Moms are very forgiving.....
Sydney, Australia
jw2170 is offline
post #4 of 15 (permalink) Old 12-24-2010, 05:15 PM
Hi Jack and Noah ,looking good ,use some WD40 on the tubes to stop the jerking, run the router up and down a time or two to get it to side nice and free b/4 you power up the router, put the dead center on the tait end ,a little deeper ,say about a 5/8" deep..this will kelp and the work, as a safety item also the router can and will kick it off the center if it hangs up..the Craftsman has a down fall with the router mounting plate, make a wedge block that fits under the router to keep the router at the right height at max,lift.The CanDo (Blue-One)router lathe I have fixed that error with plate that can move up or down, you can make one that will fit the Craftsman if you want to update it next year..
Most plunge bits will work but here's a link to some just for the router lathe.
Magnate
post #5 of 15 (permalink) Old 12-24-2010, 07:35 PM Thread Starter
First Name: Jack
Hi Jack and Noah, the Craftsman has a down fall with the router mounting plate, make a wedge block that fits under the router to keep the router at the right height at max,lift.The CanDo (Blue-One)router lathe I have fixed that error with plate that can move up or down, you can make one that will fit the Craftsman if you want to update it next year..
Hey Bob, thanks for the tip,I don't quite follow, but I will say the the CanDo model looks far more substantial than the sears.
What does the wedge block provide? My router flips right over when I tip it back, is that what the wedge prevents?
Jack
post #6 of 15 (permalink) Old 12-24-2010, 09:10 PM
Hi Jack
The wedge,, when you lift the router up to it's max the angle of the bit is off, the higher the angle the more it's off to the stock, so to say you can't drop the bit back in to the slot without moving the router to one side or the other, the wedge or angle plate takes that error out....it keeps the bit at a 90 deg. to the stock...like it should be all the way down the pass...
I will say the blue one is double the Sears in almost all ways. I put a live center on the one I have plus a template board and a way not to use the tubes for a guide points..and a small motor to help sand down the stock..
post #7 of 15 (permalink) Old 12-24-2010, 10:03 PM
CanuckGal's Avatar
First Name: Deb
That's pretty awesome Jack. Great job Noah! A nice piece and some great memories made today!
I measured, I marked, I cut.
CanuckGal is offline
post #8 of 15 (permalink) Old 12-25-2010, 03:05 PM Thread Starter
First Name: Jack
Noah and I thank you all for your kind words and encouragement. And yes, momma loved her gift, we all knew she would!
Jack
post #9 of 15 (permalink) Old 12-25-2010, 03:10 PM Thread Starter
First Name: Jack
Bob, I totally gotcha on the angle thing. I noticed that, while there may be a work around we were in a bit of a hurry as it was Christmas eve and the children exchange their gifts with each other and give us anything they have gotten for us on Christmas eve. Then on Christmas day we give them the gifts we have for them. All that to say it needed to be done that night. I looked up Cando but found NOTHING about it online.
Jack
post #10 of 15 (permalink) Old 12-25-2010, 05:04 PM
Hi Jack
see below
New Router my way reible General Routing 21 12-08-2018 12:06 PM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
owner of a canwood router lathe summit outdoor products Tools and Woodworking 0 12-30-2009 12:42 PM
Replacement Router Bits for the Craftsman Router Crafter Brian in Burlington Router Bits - Types and Usage 1 11-17-2009 12:33 PM
cable for router crafter DougO Jigs and Fixtures 9 07-01-2009 01:50 AM
