Depth gauge on plunge router - Router Forums
post #1 of 4 (permalink) Old 12-26-2010, 11:08 AM Thread Starter
First Name: Ken
Default Depth gauge on plunge router
I built a router table and ordered a router lift, template and all necessary parts to complete my project. I have a Bosch 1613 EVS plunge router and have lost my manuel. Just wanted to ask how you set the depth rod to get to my final depth.
k9holm1 is offline
post #2 of 4 (permalink) Old 12-27-2010, 12:03 AM
Hi Ken,
Welcome to the forum.
I always use brass set up bars to set my depth (above table and hand held)
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 12-27-2010, 03:25 AM
xplorx4's Avatar
First Name: Jerry
Greetings Ken and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 4 (permalink) Old 12-27-2010, 08:54 AM
LexB's Avatar
First Name: Lex
I installed a Router Raizer in my Makita 3612BR, and use that to raise/lower the router when it's table mounted. I can still use it hand-held, and that's the only time that I use the depth rod. When raising the bit above the table, I use an Incra Gauge to adjust the bit height, or just eyeball it and cut a test piece.
LexB is offline
I think my old router nearly killed me! peacefrog General Routing 23 01-26-2014 11:36 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Variable Speed Plunge Router Application MJCookSr Table-mounted Routing 2 10-22-2010 05:54 AM
Mounting a Ryobi R175 Plunge Router bobtheengineer Table-mounted Routing 6 01-14-2009 01:34 AM
Craftsman plunge router problem Edmarzo General Routing 2 07-21-2008 08:40 AM
