Changing collet - Router Forums
post #1 of 4 (permalink) Old 12-27-2010, 03:20 PM Thread Starter
First Name: Zach
Default Changing collet
I just got a router from Sears and can't figure out how to change the collet fromthe 1/2 inch to the 1/4 inch. Been looking at the book for 1/2 hour and can't figure it out. Can someone help how the bit mechanism works? Thanks. Zach
kippzd is offline
post #2 of 4 (permalink) Old 12-27-2010, 06:39 PM
dutchman 46's Avatar
First Name: Howard
Welcome to the Forum! The Collete on the router is 1/2 in. There should be a 1/2 in. to the 1/4 in. sleeve that installs into the 1/2 in. Colet. You should see some very small slits on the top, and on the bottom. I also have a straight collar and a Allen wrench there also! I hope this helps Zach
John 3:16
dutchman 46 is offline
post #3 of 4 (permalink) Old 12-27-2010, 09:53 PM
Hi Zach
Welcome to the forum
Sydney, Australia
jw2170 is offline
post #4 of 4 (permalink) Old 12-29-2010, 04:41 AM
xplorx4's Avatar
First Name: Jerry
Greetings Zach and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Mine is a model 320.17549 and each of the colletes has it's own nut
Lamentations 3:22-23
xplorx4 is offline
Jacob's Power Collet Questions cdevlync General Routing 5 10-20-2010 11:07 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
Help: Changing collet chuck realexander General Routing 9 04-24-2009 04:11 PM
