Is variable speed important for Colt? - Router Forums
post #1 of 5 (permalink) Old 12-27-2010, 07:40 PM Thread Starter
crquack's Avatar
Default Is variable speed important for Colt?
Is it? I can get one with fixed speed considerably cheaper.
crquack is offline
post #2 of 5 (permalink) Old 12-27-2010, 07:44 PM
Hi
Yes= After all it's a trim router, you don't want to cook your bits. or maybe you do
post #3 of 5 (permalink) Old 12-27-2010, 09:25 PM
First Name: Steven
I own a variable speed Colt and wouldn't have it any other way. My rule is always buy variable speed, if offered. Also, on Amazon they're super cheap either way. $97 for variable speed vs $93 for fixed.
In particular when doing delicate flush trim routing, I find that the slower speeds are easier to control. Most of the time, I use the max speed, but I find that the max speed generates more heat and is more likely to burn or fly out of control when doing light roundover (1/8" radius) or light flush trimming.
I'd be interested to hear responses from other users.
JavaGeek is offline
post #4 of 5 (permalink) Old 12-27-2010, 11:52 PM
Does anyone ever run the thing at 35,000 anyway? My Trend T-4 has a max of 32K and I don't think I have every run it over half speed (~22,00).
John Schaben
jschaben is offline
post #5 of 5 (permalink) Old 12-28-2010, 05:05 PM Thread Starter
crquack's Avatar
That's what I figured. There is a reason why they are cheaper. I think all my other routers top out at 24,000 rpm. I am not anxious to find out what hapens if you run the bits 50% faster.
crquack is offline
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 10:38 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Variable Speed Controlers Timberline Table-mounted Routing 4 08-27-2010 09:55 AM
Router Bit Sizes And Variable Speed Settings mack. Router Bits - Types and Usage 4 02-18-2010 11:33 PM
Is variable speed important? S Bolton General Routing 9 09-29-2007 12:37 AM
