Newby question on a Rockwell/delta 43502 over arm router shaper - Router Forums
post #1 of 2 (permalink) Old 12-29-2010, 08:41 AM Thread Starter
First Name: Bob
Default Newby question on a Rockwell/delta 43502 over arm router shaper
Thanks for you forum guys My name is Bob
I have just purchased an interesting older model Rockwell/ Delta overarm router shaper 43-502. It really works great as a overarm pin router and shaper but i wanted to use it with the motor mounted on the bottom as a high speed shaper. I have found that the bed center hole is not centered with the bottom motor mount. I have taken the bed apart and do not see much way of adjusting the bed plate without oversizing the mounting holes. Has anyone had any experience with this type of router shaper.
I want to use it with a lock joint mitre bit but the circumference of the Bit is offset and ovelaps the circumferene of the hole by about 1/4" and I really do not have enough shank on the Bit to extend above the hole safely.
Bob Bratton
lumbertrader is offline
post #2 of 2 (permalink) Old 12-29-2010, 11:57 AM
dutchman 46's Avatar
First Name: Howard
Hello Bob! Welcome to the forum. I don't know about your set-up, but I know a lot of talanted people here who may have a working knowledge. Thanks for joining, and enjoy the forum:
John 3:16
dutchman 46 is offline
For Sale: Delta 43-505 router shaper Mike Woodworking Classifieds 9 10-15-2017 09:13 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Router table vs Shaper guillta Table-mounted Routing 5 12-29-2009 04:30 AM
