Track lighting router groove - Router Forums
post #1 of 4 (permalink) Old 12-30-2010, 08:54 AM Thread Starter
First Name: jerry
Default Track lighting router groove
A friend wants me to make him an oval poker table. Just under the padded outside rail he wants track lighting with a plexi diffuser . I can not come up with a good way to route a consistent 1/8 groove to set the plexi in. guide will not be accurate around the oval. I can make a smaller wood oval template double tape down for my router offset, but would use good ply and probably never use the template again. Any suggestions other than forgetting the router and trying another way to make diffuser stable. Thanks
nwjerry is offline
post #2 of 4 (permalink) Old 12-30-2010, 09:34 AM
Ralph Barker's Avatar
First Name: Ralph
Absent an oval template drawn from the same dual centers as the table, I think it would be difficult to get the groove exactly concentric with the edge of the table. But, you might come close by using an edge guide, keeping the face of the edge guide perpendicular to the radial lines of the oval. Another approach would be to attach two rounded protrusions to the face of the edge guide, so they would track around the arc.
- Ralph
Ralph Barker is offline
post #3 of 4 (permalink) Old 12-30-2010, 09:55 AM
Best Sellers - Combination Arched Fluting Jig & Edge Guide
Or make your own like I did 3 bearings and a slot or two and you have it.
http://www.routerforums.com/215962-post2.html
post #4 of 4 (permalink) Old 12-30-2010, 03:00 PM Thread Starter
First Name: jerry
Good ideas, thanks, that is why the forum is so good, wealth of knowledge. thanks again
nwjerry is offline
V Tongue and Groove router bit darkstar Router Bits - Types and Usage 14 12-01-2009 10:01 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
Shop Fox W1728 router mounting issues SkidSTL Tools and Woodworking 6 03-04-2009 06:42 PM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
