Question about plunge base on Ridgid router - Router Forums
post #1 of 13 (permalink) Old 12-30-2010, 10:16 PM Thread Starter
Default Question about plunge base on Ridgid router
I got the Ridgid router combo for Christmas. So far it is a great router, but I have a question about the plunge base. I have never used a plunge base before, so I don't know if this is normal or not. The plunge base plunges smooth when you use both hands and the bottom of the base is completely supported by a work piece. But if I have a bit with a bearing on it and want to set the plunge for a certain depth of cut and try to plunge on the edge of a workpiece, it is very hard to plunge. It seems like any slight pressure that is not totally downward causes it to stick. Is the just the way plunge bases are? Should the plunge only be smooth if the base is completely supported by a work piece? If I have slightly less pressure on one hand on a bit more on the other it sticks too. I have lubed everything that can be lubed. Any ideas? I don't want to return the router if I just don't know what I am doing.
Sawatzky is offline
post #2 of 13 (permalink) Old 12-30-2010, 10:54 PM
xplorx4's Avatar
First Name: Jerry
I use mine mostly in the table, but a few times as a plunge router and I do not remember that problem. You have 90 days if bought through HD to return it.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 13 (permalink) Old 12-31-2010, 06:21 AM
dutchman 46's Avatar
First Name: Howard
Hello n/a The question that I have is why use a bit with bearing to plunge? The bit height should be set when routing with a bearing. It is made to run the bearing along a pattern. That would be My use any way. In order to help you better, Please add a name to your profile! Thank you.
John 3:16
dutchman 46 is offline
post #4 of 13 (permalink) Old 12-31-2010, 11:14 AM
darrink's Avatar
First Name: Darrin
Send a message via Skype™ to darrink
I agree with Howard. I can't think of a situation where I would plunge with a bit with a bearing on it. I'd use the fixed base.
I am somewhat new to this myself, so if there is a situation where this is the correct method, let me know.
Thanks!
Darrin
darrink is offline
post #5 of 13 (permalink) Old 12-31-2010, 11:23 AM
Hi
Many bits with bearings on them can be use to plunge in , pattern bit for just one of many
Pattern/Flush Trim Bits
http://www.mlcswoodworking.com/shops..._bottom_anchor
As to the router having errors ,put it back in the box and return it and get one more..you don't want to use a router that's not right from the get go.
post #6 of 13 (permalink) Old 12-31-2010, 12:32 PM Thread Starter
What I am actually trying to do is set the depth to use the plunge base to rout the edge of a workpiece with a bearing bit. If I try to use the plunge to eyeball the depth but only have the base of the router on part of the work piece, the plunge does not work well.
Sawatzky is offline
post #7 of 13 (permalink) Old 12-31-2010, 01:39 PM
darrink's Avatar
First Name: Darrin
Hi
MLCS Flush Trim and Shear Angle Flush Trim Router Bits
BJ
You are correct. I was thinking of a bottom mounted bearing, and for some reason a bit with top mounted bearing never crossed my mind.
Darrin
darrink is offline
post #8 of 13 (permalink) Old 12-31-2010, 03:02 PM
Hi
If the Columns are set right it should work right 1/2 on or 1/2 off the stock..and it should not jam at any point..parallel tubes should be dead on.. pack it up
post #9 of 13 (permalink) Old 12-31-2010, 03:38 PM
First Name: Howard
Your correct, Bob! If it were a bottom bearing bit, which I took it for, It would not work! I generally set the height of the bit to be on the template, and follow the pattern around. It would seem to Me that if You are running a bearing bit, set the height, and forget it. To many mistakes can be made when attempting additional operations. It You are plunging through the project, You are cutting it out, and finishing the edge with the bearing? !
John 3:16
post #10 of 13 (permalink) Old 12-31-2010, 04:49 PM
Hi Howard
Many get a true panel cutting bit in some router bit sets and they don't know what to do with them,,it's router bit with a sharp point on it , one cutter the norm made just for plunging in and cutting out a panel..no bearing the norm, many use them to cut out a windows/doors holes,just plunge in and the bit will follow the 2 x 4 frame on the back side. one more note many plunge bits for making MDF cabinet doors are setup with the same type of bit, cutter than bearing in place.
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
question on Craftsman two base router oldfolks Table-mounted Routing 3 12-29-2008 08:18 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
