Power switch vibrates off - Router Forums
post #1 of 10 (permalink) Old 01-04-2011, 10:03 AM Thread Starter
Default Power switch vibrates off
I am new to using a router and am having a major issue with my router.
I aquired an older Craftsman router with a switch that you slide on and off. When I turn the router on the vibration from the unit causes the switch to move back to the off position. (very frustrating)
Is the a fix for this problem? A way to tighten up the switch?
Thank you in advance for any help you can offer.
jc5066 is offline
post #2 of 10 (permalink) Old 01-04-2011, 10:16 AM
Hi
If you are getting that much vibrations out of your router it's time to replace it..
If you want to keep it and use it just pickup a router speed control box ,glue the switch to the on,and just use the control box.
http://www.harborfreight.com/router-...rol-43060.html
post #3 of 10 (permalink) Old 01-04-2011, 10:21 AM
Ralph Barker's Avatar
First Name: Ralph
Excessive vibration may be an indicator of worn bearings, which can be potentially dangerous. But, it sounds like the switch is worn, too. You might try replacing the switch if you can find the part. Or, you might decide to simply replace the router.
- Ralph
Ralph Barker is offline
post #4 of 10 (permalink) Old 01-04-2011, 02:34 PM Thread Starter
Thank you for the quick replies.
I don't think it vibrates as much as the switch is really loose.
I may have to try the variable switch idea.
jc5066 is offline
post #5 of 10 (permalink) Old 01-04-2011, 09:49 PM
metzgeri's Avatar
First Name: Tim
Just a thought, but could the switch be tripping like a circuit breaker because of a short? Could Craftsman have used such a switch? I have seen tools like that before.
Regards,
Tim
Words to be raised by: "I am I plus my circumstances"
Words to Live by: "Proper Planning Prevents Piss Poor Performance"
Words to die by: "Arbeit Macht Frei"
metzgeri is offline
post #6 of 10 (permalink) Old 01-05-2011, 07:45 AM Thread Starter
Regards,
Tim
Definitely not the case. You can watch the switch slowly slide back into place.
jc5066 is offline
post #7 of 10 (permalink) Old 01-05-2011, 10:02 AM
Hi JC - What's the model number on the thing. Would help if I could look up a parts explode for it
John Schaben
jschaben is offline
post #8 of 10 (permalink) Old 01-05-2011, 11:17 AM
First Name: Ralph
Of course, there's always duct tape.
- Ralph
post #9 of 10 (permalink) Old 01-06-2011, 08:02 AM
Knothead47's Avatar
Duct tape can fix anything!
Knothead47 is offline
post #10 of 10 (permalink) Old 01-06-2011, 09:55 AM
But it's real nasty stuff after a day or two, little bit of heat and you have a real mess.
Bosch 1617 switch repair reikimaster General Routing 37 06-18-2017 08:33 PM
Power switch for router table? Birch Table-mounted Routing 128 10-25-2012 04:45 PM
Router Table Power Switch dpete3616 Table-mounted Routing 9 05-09-2010 04:34 PM
Safety Power Tool Switch kmcbride21 Table-mounted Routing 12 12-23-2009 05:38 PM
Rockler Safety Power Tool Switch 1/3 off Ladd The Bargain Bin 3 12-16-2007 03:45 PM
