Hitachi m12vc2 - Router Forums
post #1 of 16 (permalink) Old 01-09-2011, 05:31 PM Thread Starter
papawd's Avatar
First Name: warren
Default Hitachi m12vc2
The Hitachi router combo looks nice and is one on my list of what to buy and start with. I was wondering if anyine has this and or having any problems as I read a few reviews saying it was hard to mount on table and plunge base was stiff anyone have this? Some of my other choices are Bosch 1617 EVSPK, Milwaukee 5615-21, Makita 3612C and of course the Porter Cable models. My thinking is buying a combo would save a few dollars as mounting the fixed base in table (when I buy it ) and I would have the plunger when needed. I do already have a Ridgid laminate router which I purchased to do some engraving on a box for my grandson so may not need the plunger any input or suggestions would be welcome.
papawd is offline
post #2 of 16 (permalink) Old 01-09-2011, 05:57 PM
Hi Warren - I've had that kit for almost two years now and it's still my go to machine for most hand held work. Plunge was a bit stiff when I first got it but it smoothed out in a couple of weeks. Either that or I got used to it. I like the way the plunge locks on lever release but that's more a personal preference. The others I have I need to move the lever to lock it which, to me, is a point of distraction. I don't think I would like it in the table with either base. With the fixed base, the motor needs to be rotated to change cut depth so the on/off switch and speed control are in a different spot each time as well as the cord wanting to wrap around. Plunge base may be a bit better but I wouldn't swap the Freud out of the table for it.
I haven't got any of the others you mentioned but don't forget the Sears models, I've heard good things about them on this forum.
Good Luck
John Schaben
jschaben is offline
post #3 of 16 (permalink) Old 01-09-2011, 06:18 PM Thread Starter
papawd's Avatar
First Name: warren
I do have a small Craftsman table that was a combo w/router the router does seem strong but the table is small and I am redoing my shop want something larger and more of a permanent type as the tables I have been looking at are much larger, also the router has a tendency to slip in the height adjustment so this set-up is for sale.
papawd is offline
post #4 of 16 (permalink) Old 01-09-2011, 10:37 PM
Hi Warren - I wasn't referring to a Craftsman router/table combination. Some of the newer Craftsman fixed base/plunge base combination kits also offer "through the table" height adjustments. Sorry, I can't give a model number but one of the other members may jump in here for you.
John Schaben
jschaben is offline
post #5 of 16 (permalink) Old 01-10-2011, 09:34 PM
Default stiff plunge
I have a M12V2 and at times it can be a little stiff. Allthunbs has 2 of them and he suggested taking the tubes out and waxing them. Haven't gotten around to it yet but it should work. I love everything else about the router.
post #6 of 16 (permalink) Old 01-10-2011, 10:08 PM
Hi Chuck - the VC is the baby brother of the V2 and is a different animal. I put a little dry graphite lube on mine two years ago when I got it and haven't touched it since.
John Schaben
jschaben is offline
post #7 of 16 (permalink) Old 01-10-2011, 10:24 PM Thread Starter
papawd's Avatar
First Name: warren
Sounds good a little dry lube graphite, I think that could be arranged all the reviews I have been reeding say it has nice power, only thing I am worried about is mounting it in whichever table I decide to buy as some have said either they would not table mount it or they have had trouble mounting it in a table
papawd is offline
post #8 of 16 (permalink) Old 01-10-2011, 11:41 PM
Hi Warren - I think I'm the one that said I wouldn't mount it in a table. It's a great little router but I use it exclusively hand held, either with fixed or plunge base, whichever the job requires. Two things make it less than optimum for table mounting.
1. Lack of a spindle lock. Needs two wrenches to change bits almost guarantees motor removal each time a bit needs changed.
2. Height adjustment with the fixed base requires rotating the motor. Not terrible but a hassle with the cord wanting to wrap around, speed control and switch changing position.
I'm not saying it wont work in a table, just that there are better choices. I use a Freud 1700 in my table (now discontinued) which has above table bit changes and height adjustment.
Hope this helps
John Schaben
jschaben is offline
post #9 of 16 (permalink) Old 01-11-2011, 11:37 AM
boogalee's Avatar
First Name: Al
Warren
I have a bosch 1617 and a rockler plate mounted in my table. I am very happy with it's performance. For hand held work I use Bosch 1617evs with plunge base (mostly). For smaller work I use Bosch Colt an I just order a Trend T4.
You can not have enough clamps or routers.
Al
boogalee is offline
post #10 of 16 (permalink) Old 01-11-2011, 03:59 PM
Thanks for the tip John, I'll give that a try.
Cordless Drill Hitachi DB3DL Manual Manuals Hitachi Manuals 0 12-16-2010 12:18 AM
Power Hammer Hitachi WH18DFL Manual Manuals Hitachi Manuals 0 12-15-2010 11:58 PM
Cordless Drill Hitachi DV18DL Manual Manuals Hitachi Manuals 0 12-15-2010 11:47 PM
Cordless Drill Hitachi DS18DL Manual Manuals Hitachi Manuals 0 12-15-2010 11:28 PM
Cordless Saw Hitachi C18DL Manual Manuals Hitachi Manuals 0 12-15-2010 11:11 PM
