hitachi m12 base not square - Router Forums
post #1 of 10 (permalink) Old 01-10-2011, 05:40 PM Thread Starter
Default hitachi m12 base not square
is there an adjustment for square with the bit. i tore the machine apart and could not find anything.
robertjenns is offline
post #2 of 10 (permalink) Old 01-10-2011, 06:30 PM
Ralph Barker's Avatar
First Name: Ralph
The M12 has a flat side on the base to register against a guide fence for things like cutting dados. Since the bit is round, however, "square" doesn't apply in the usual sense. Or, am I misunderstanding your question?
- Ralph
Ralph Barker is offline
post #3 of 10 (permalink) Old 01-10-2011, 06:50 PM
HI Robert
" is there an adjustment for square with the bit. " = ??????
The bit should come down 90 deg. to the base plate without any help from you, if it's not take the router back to the store
post #4 of 10 (permalink) Old 01-11-2011, 06:01 AM Thread Starter
bobj3 you are right. the router is a number of years old and cannot be returned, but i was hoping to correct the problem. it still plunges and runs great, but when using templates and guides it is inaccurate for presicion work. i just thought maybe someone would know a fix without reengineering the machine.
post #5 of 10 (permalink) Old 01-11-2011, 07:43 AM
Hi Robert
It sounds like the bit is not coming down in dead center of the guides, many ways to fix that one, the easy way is just pickup a Milescraft base plate and it comes with a line up pin so you can can use your router " presicion ".....
Amazon.com: Milescraft 1211 Base Plate Metal-Nose Bushing Set for Routers: Home Improvement
post #6 of 10 (permalink) Old 01-11-2011, 04:37 PM
Bob may have hit on the real problem which is that the base is not centered. Try lightly chucking a 1/2" drill bit (the standard type) or a 1/4" if you don't have a 1/2". Then take a square and check to see if the bit is straight from at least 4 different directions. If it really is off I don't know of a fix.
post #7 of 10 (permalink) Old 01-11-2011, 05:39 PM Thread Starter
good idea. i was using my longest plunge bit which was hard to tell accurately whether it is square or like you said not centered. i guess the solution that bobj3 is an aftermarket baseplate that will mount with no trouble to my router and i will then have the ability to adjust for center if that is the problem. thanks guys.
post #8 of 10 (permalink) Old 01-11-2011, 05:56 PM Thread Starter
"presicion" should be a word. no?
post #9 of 10 (permalink) Old 01-11-2011, 06:30 PM
allthunbs's Avatar
First Name: Ron
Hi Robert:
Take a look at the point where your columns attach to the base. Is there any signs of a wrinkle or bend? Look down the insides of the column tubes. It sounds like you've got the kind of damage from being dropped. The fix is to get a pair of new columns. You may need a machine shop to shrink and press the new columns into the base.
Allthunbs
allthunbs is offline
post #10 of 10 (permalink) Old 01-14-2011, 06:14 AM Thread Starter
the columns are definetly out of square. i will take it to a repair shop to see if they can correct it. thanks again.
Square vs. round base. rstermer General Routing 13 04-20-2011 05:17 PM
Hitachi m12vc base removal question Jay Gonsalves General Routing 8 01-01-2011 01:17 PM
Hitachi m12 and speed control TLC General Routing 8 12-13-2009 08:59 PM
Hitachi Router Base RustyW General Routing 4 07-28-2006 06:53 PM
Hitachi m12vc sub base question Cactus Carl General Routing 4 09-12-2005 08:29 AM
