Centering the base plate? - Router Forums
post #1 of 7 (permalink) Old 01-15-2011, 07:05 PM Thread Starter
30coupe's Avatar
First Name: Russ
Default Centering the base plate?
I can see that you would want to center the base plate on your router, and I understand how you could do that on a blank plate before you drill the mounting holes. What I wonder about is how you would center one that is already drilled. MLCS has a PC style universal plate that comes with a centering tool. Is the tool just to help you figure out which of the dozen or so holes to use or is it possible to shift the plate after the screws are snug but not tight? If so, I'd be a little concerned about how well it is going to stay centered.
30coupe is offline
post #2 of 7 (permalink) Old 01-15-2011, 08:19 PM
Hi Russ
Once you button it down it will stay in place..
Tool, yes ,it will let you spin the plate to get it to line up on the screw holes, if you are talking about the base plate on the router.
The mounting plate for the router table, some times you will need to drill the holes over size a little bit to get it to line up with the center hole..
post #3 of 7 (permalink) Old 01-16-2011, 01:52 PM Thread Starter
30coupe's Avatar
First Name: Russ
Hi Russ
So, is this a must have item or would a set of PC style brass bushings and a 1/4 or 1/2 in drill bit do the trick?
30coupe is offline
post #4 of 7 (permalink) Old 01-16-2011, 02:52 PM
HI Russ
No it's not a must have item and the guides will do the job just fine.
post #5 of 7 (permalink) Old 01-16-2011, 07:03 PM Thread Starter
30coupe's Avatar
First Name: Russ
Thanks, Bob!
30coupe is offline
post #6 of 7 (permalink) Old 01-16-2011, 07:40 PM
Your Welcome Russ
post #7 of 7 (permalink) Old 01-18-2011, 06:51 PM
Zurt's Avatar
First Name: Burt
I put a Jasper base plate on my Bosch 1617 so I could use PC guides. It was way off center. I had one of those centering sticks so I loosened the pllate and put a guide in that would accept the stick tightly. The plate pretty much centered itself so I just tightened it up. Not a problem since.
In place of a centering stick (or whatever they are called), you could probably use a drill bit. Just make sure it fits tightly in the guide.
Zurt is offline
Centering your router on a mounting plate Mike Table-mounted Routing 61 01-08-2016 10:28 AM
Best Base Plate BearLeeAlive Portable Routing 25 08-19-2010 11:41 AM
DIY Base Plate and Table bcskinz DIY and Renovation 7 03-25-2010 10:32 AM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 10:37 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 10:15 AM
