68 degree cut - Router Forums
post #1 of 5 (permalink) Old 01-21-2011, 12:47 PM Thread Starter
Default 68 degree cut
i need to make a 68 degree cut for the roof of my windmill can you help me clayt
clayton borger is offline
post #2 of 5 (permalink) Old 01-21-2011, 01:07 PM
Gene Howe's Avatar
First Name: Gene
Bevel cut? miter cut? Or, taper?
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #3 of 5 (permalink) Old 01-21-2011, 01:29 PM
Hi Clay
That's going to be a hard one in the router table I would suggest you use the RAS..it will do a 68 deg.cut easy..
But I will say you can made a jig for the router table and do a compound angle on the router table,look at the planer jig ( from RWS) for the router table for a tip how to made the jig, and use a trim router bit for the job..
post #4 of 5 (permalink) Old 01-21-2011, 04:50 PM
OPG3's Avatar
First Name: Otis
I had need to make some prismoidal demos for a physics class I was teaching to my senior employees a couple of years ago. To be honest, I wasted several parts prior to getting what I was in need of. If your roof is to be the shape of a prismoid (frustum of a pyramid), the best way I came-up with was to use my sliding compound miter saw, which is a Makita LS1013. I built-up an angled support to be bolted to the saw's fence.
Divide 360 (degrees) by the number of hip cuts that are needed (i.e. 8 if it's 4- sided or 10 if it's 5- sided), which gives you 45 (degrees). Adjust miter angle only, because your bevel part of the cut is taken care of with the workpiece being supported by your angled support. It's a tricky cut, that needs precise alignment - but after making a couple of cuts you'll realize it's a smart and safe way to make the cuts. Routers are wonderful, but 68 degrees is not an angle best handled with a router. OPG3
OPG3 is offline
post #5 of 5 (permalink) Old 01-21-2011, 05:20 PM
G'day Clayton
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
Dovetail bit question 8 degree versus 14 degree. Timmberman Router Bits - Types and Usage 9 07-04-2018 10:27 AM
120 degree V grooving bit? patrick_g Router Bits - Types and Usage 14 04-20-2014 02:14 PM
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Weatherwatch. derek willis Table-mounted Routing 11 02-14-2009 03:41 AM
Up Cut... Down Cut... Joe Lyddon Router Bits - Types and Usage 2 09-10-2006 06:21 PM
