68 degree cuts - Router Forums
post #1 of 4 (permalink) Old 01-21-2011, 07:09 PM Thread Starter
Default 68 degree cuts
my lighthouse plan calls for a 68 degree cut on the roof how do i do a 68 degree cot on 3/8 ply wood clayt
cab0911 is offline
post #2 of 4 (permalink) Old 01-21-2011, 07:21 PM
Hi
Drop Mike a note and ask him how he did it.. he has made many of them....
http://www.routerforums.com/show-n-t...ghthouses.html
post #3 of 4 (permalink) Old 01-22-2011, 05:08 AM
G'day Clay
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 4 (permalink) Old 01-22-2011, 11:52 AM
Hi, Welcome.
Question not real clear. I'm guessing it is a round light house. Is that around the circumference so it would be an 8 sided piece or the roof pitch? If being the circumference it would really be the opposite of 68 which is 22. That comes from a starting point of 90 - 68 = 22. If 8 sided the cuts would be 22.5. Added all together it would equal 360 (full circle).
If for the roof pitch (taper)I would make a simple tapering jig to use with the table saw. It would still probably be a compound cut so you would need to tilt the blade to the degrees needed to make a circle when glued together. The math to make a complete circle is 360 (number of sides) gives joint degrees. Divide that by 2 gives cut degrees for each side of joint.
Example for 8 sides: 360 8(sides) = 45 2 = 22.5
Your cuts will be 22.5 on each end of your pieces. Put together you will have a complete circle. The length of each piece would depend on the total circumference that you need.
Whittier, CA.
Have a nice & safe day!
jlord is offline
Dovetail bit question 8 degree versus 14 degree. Timmberman Router Bits - Types and Usage 9 07-04-2018 10:27 AM
120 degree V grooving bit? patrick_g Router Bits - Types and Usage 14 04-20-2014 02:14 PM
Box cuts - table router Cochese Shop Safety 5 01-20-2010 04:40 PM
Dado cuts on bookshelf djmoss Table-mounted Routing 2 11-25-2008 09:41 AM
routing cross cuts on 2x10 pine for a bookcase QuietIrishman General Routing 6 08-18-2008 10:42 AM
