Router Forums (https://www.routerforums.com/forum.php)
-   General Routing (https://www.routerforums.com/general-routing/)
-   -   Can a trim router do dovetails, etc.? (https://www.routerforums.com/general-routing/26107-can-trim-router-do-dovetails-etc.html)
LBrandt 01-21-2011 09:13 PM
Hello,
I've been looking at the new DeWalt DW611pk trim router combo, and I've been waiting for my local HD or Lowe's to get it, but before I do, I need to know whether it (or any trim router) has the capability to do things like dovetails, hinge mortising, etc.
I already have a full-size Bosch 1617EVSPK, and of course, I know that it is capable of dovetails, etc. Obviously this means that I don't absolutely need a trim router, but I'd like to have one, if I can justify it.
I'm sure that there would be instances (like simple roundovers, etc.) where a trim router might be more convienient than a full-size router, but if that's the only thing that I'd gain from a trim router, I might pass on it.
On the other hand, if a trim router would be good for things like hinge mortising, etc., I might go for it, but my big question is, could a trim router do something as complicated as dovetails, or would it be a mistake to use one for this?
Thanks,
Louis
jlord 01-21-2011 10:17 PM
Hi Louis,
A trim router will do dovetails if that's all you have. I prefer a router with more power than a trim router. I do use them for hinge mortising because of the size & weight. Hinge mortising removes very little each pass.
Ralph Barker 01-22-2011 01:33 AM
A lot depends on the types of wood you are using. Harder woods need more HP to get the job done. With softer woods, or particularly if using a mini-DT jig with thin stock, the smaller router might be just fine.
Plus, the 611 is a notch up from the typical trim router - 1.25hp/7amp compared to 3/4hp or around 5.5 amps on the typical laminate trimmer.
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
