Hot/warm collet? - Router Forums
post #1 of 5 (permalink) Old 01-22-2011, 08:00 PM Thread Starter
First Name: Ron
Question Hot/warm collet?
Good evening everyone. I've found that the collet[ & even the router bit shaft] on my Freud 3 1/2 H.P router seem to be getting fairly warm after using it for even short times. What would you suggest the cause might be? Possibly the motor going?
third base is offline
post #2 of 5 (permalink) Old 01-22-2011, 09:28 PM
BrianS's Avatar
First Name: Brian
Hi Ron, welcome to our little corner of the 'net.
I wouldn't think there is anything unusual about your router bit shaft and collet getting warm, or even hot. The cutter on the bit gets hot from cutting the wood and consequently transfers heat to the bit shank and collet.
As for the motor going, keep it clean by blowing compressed air thru it once in a while to clean the sawdust out and it should last you a long time.
Brian
(Origin uncertain)
BrianS is offline
post #3 of 5 (permalink) Old 01-22-2011, 10:23 PM
G'day Ron
Welcome to the router forum.
Thank you for joining us
I agree with Brian. However if you consider the unit is getting too hot then maybe you should look at the top bearing.
How old is your router?
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 01-23-2011, 02:41 AM
xplorx4's Avatar
First Name: Jerry
Greetings Ron and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #5 of 5 (permalink) Old 01-23-2011, 09:57 AM
First Name: Jimmie
Ron, I agree Brian but if the collet gets hot without you cutting wood ie; just turning the router on then there could be a bad lower bearing and if so should be replaced asap. Robbie
robersonjr is offline
Stuck collet on router - help tkm795 General Routing 5 01-13-2011 08:53 PM
Jacob's Power Collet Questions cdevlync General Routing 5 10-20-2010 11:07 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Makita 3612 collet nut and collet cone needed cheap Zappacat General Routing 5 07-18-2009 12:33 PM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
