Dewalt 611pk collet - Router Forums
post #1 of 9 (permalink) Old 01-27-2011, 04:06 PM Thread Starter
Zurt's Avatar
First Name: Burt
Default Dewalt 611pk collet
Just opened the Amazon package for the 611. No 1/2" collet. Checking around, it seems like a 1/2" collet is no included. Is this so?
Where does one get a collet to fit this router? Initial google search didn't turn up anything.
Zurt is offline
post #2 of 9 (permalink) Old 01-27-2011, 04:10 PM
Hi
It's a 1/4" shaft router only
post #3 of 9 (permalink) Old 01-27-2011, 05:18 PM Thread Starter
Zurt's Avatar
First Name: Burt
After using a flush trimmer I realized that it probably wouldn't do as a 1/2". However, it is a very fun router. The weight is nice and the handling is very good.
Unfortunately, or fortunately, your choice, I really need a second router with a 1/2" collet. I don't have any intention of sending the 611 back but I'm not budgeted to buy a 4th router.
BTW, when I searched for 611 w 1/2" collet I got a lot of hits but they must have been deleted because I could not find any reference to 1/2" collets anywhere.
One good thing about this router is it's easier to make test cuts for techniques that I'm somewhat apprehensive about.
Zurt is offline
post #4 of 9 (permalink) Old 01-27-2011, 06:51 PM
HI Burt
What did you want to do with it, most of the 1/2" shank bits can be had in the 1/4" shanks,,that's right like the small panel cutters as well..but you will need to put out some more money out for a bigger hole base plate like the Milescraft that will let you use up to a 2 " OD bit...and yes the 611 has the power to spin them.
I can tell you how to use 1/2" diam.bits in it but the last time I told someone how to do it I got tons of neg.feed back from other members so I will pass this time..but you will also need to put out more money also..and have a metal lathe.
post #5 of 9 (permalink) Old 01-27-2011, 07:09 PM Thread Starter
Zurt's Avatar
First Name: Burt
I have all the bits I need...I think. Most are 1/2" shanks. I have a very few 1/4" shanks but that could change. I don't want to duplicate because I'm not the Bank of Obama. Mostly, what would be good for this router is the finishing touches like a trimmer, which I have and round overs which I have in 1/2".
My current project is the construction of tissue box covers. So far, the wife loves them. As my skills progress, I add a few more "touches." One project for the 611 will be for hinges.
I'd like to get into inlays which I think this router would be terrific for since it is so light and easily maneuverable. Any hints there are appreciated.
But, now I"m rambling...
Zurt is offline
post #6 of 9 (permalink) Old 01-27-2011, 07:25 PM
Hi Burt
Like they say it's time to retool, get one of the 1/4" 30 bit sets and you should have what you need..the little 611 can and will do it all..you don't need a tank router for most of the router jobs..
Super Carbide Tools items - Get great deals on items on eBay Stores!
I have one and use it all the time..
post #7 of 9 (permalink) Old 01-27-2011, 09:03 PM Thread Starter
Zurt's Avatar
First Name: Burt
Bob J.,
Your post makes a lot of sense. I'll probably pick this set up and not worry about having to buy another router. Since a lot of my work is small, this could help out.
Thanks,
Burt
Zurt is offline
post #8 of 9 (permalink) Old 01-28-2011, 08:56 AM Thread Starter
Zurt's Avatar
First Name: Burt
Just bought the set from ebay. Thought about it overnight and it made a lot of sense.
Thanks for that tip!
Burt
Zurt is offline
post #9 of 9 (permalink) Old 01-28-2011, 10:05 AM
Sounds great Burt, now go out and pickup a Milescraft base plate so you can use the bigger OD bits in the router...note some of the bits are 1 3/8"/1 1/2" OD and will not fit into the 611 stock base plate..
Burt
Stuck Collet Dewalt 625 ogee General Routing 12 11-10-2018 10:56 AM
DeWalt 611PK bobj3 Portable Routing 9 12-29-2010 02:18 AM
dewalt 621 collet question diegoh2 General Routing 3 04-20-2010 09:34 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Where buy 1/2" collet DeWalt 621? charleyb General Routing 5 10-07-2009 09:37 PM
