Craftsman Router Screw Size - Router Forums
post #1 of 4 (permalink) Old 01-30-2011, 12:03 AM Thread Starter
Default Craftsman Router Screw Size
I have a Craftsman plunge router, model 320.1740. It is the common one you see today in silver color 9.5 amps. I paid no attention to it years ago when it came. But it is missing the lock bolts as it is called in the parts manual. They are the ones the lock down the depth rod and the two that hold the rods for a guide if one is used. According to the parts they are all the same. Does anyone know what size screws they are. It looks like 3/16 diameter, but what size thread I need to know. Knowing my misfortune I will get the wrong screw. I called the parts department and I was told they are no longer made and she had no more info on it. I would like to get something with a knob on it as well if someone knows where to order three that will fit. Any info is greatly appreciated. Thanks
Pitts Special is offline
post #2 of 4 (permalink) Old 01-30-2011, 03:01 PM
CharleyL's Avatar
First Name: Charley
Many of the bigger hardware stores have drawer boxes loaded with all kinds of bolts, nuts, cotter pins, woodruff keys, and almost any other kind of hardware that is frequently in need of replacement. They even carry motor brushes for small electric motors. If you take your router there and explain what you need, they can likely come up with something that will work and it may even look exactly like what is shown in the manual. The big box stores have similar assortments in drawers, but they only stock what sells frequently. The better stocked local hardware store are more likely to have what you are looking for.
Charley
CharleyL is online now
post #3 of 4 (permalink) Old 06-28-2014, 03:05 PM
Default Screw Size
Had not used my router table for some time and had lost the mounting screws. Internet search of Sears revealed little other than a flat head screw is used (3 total). The answer for my stuff was a # 10 machine screw with fine threads. length is .75 inch. At your local hard ware ask for machine screw 10-32 by 3/4 inch.
The 32 is 32 threads per inch (fine thread). Number 10 screws are also commonly sold with 24 tpi (course thread). Using the course will ether damage the screw or your router. The 3/4 inch works for my aluminum (rather thin and cheap) table.
Sandmann is offline
post #4 of 4 (permalink) Old 06-28-2014, 04:44 PM
MT Stringer's Avatar
When I can't find hardware I need, I go to our local Ace Hardware. They usually have a good assortment. Might cost a little more, but if they have it, then that's OK.
Take you router to the store with you...and tell them you lost your screws!
MT Stringer is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
opinions on Craftsman Professional router Sawatzky Table-mounted Routing 11 06-21-2010 07:34 PM
Table mounting questions for a Craftsman router. tdsapp Table-mounted Routing 25 12-17-2009 07:58 PM
Does the Size of Router Plates differ? Chris_Barry Table-mounted Routing 1 01-29-2008 05:22 PM
