M12v / m12vc - Router Forums
post #1 of 7 (permalink) Old 01-31-2011, 03:32 PM Thread Starter
jhsteele3's Avatar
Default M12v / m12vc
What is the difference? Specifically, I have an M12V that I am now looking for a router table. Most pre-made tables can accommodate the M12VC. Will the M12V work in these tables or do I need to modify?
Thanks for your help
John
jhsteele3 is offline
post #2 of 7 (permalink) Old 01-31-2011, 04:52 PM
John
Hi John - M12V and the M12VC are completely different animals. The VC is a 2-1/4 HP and the V is a 3+ HP. I have the VC and seriously doubt it shares a bolt pattern with it's big brother.
John Schaben
jschaben is offline
post #3 of 7 (permalink) Old 01-31-2011, 07:58 PM
John
Hi John,
I have the Hitachi M12V 3-1/4hp & love it. It is also an older model router. As John said the M12VC is a newer generation 2-1/4hp router. The newer generation 3-1/4hp is the M12V2.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #4 of 7 (permalink) Old 01-31-2011, 08:24 PM Thread Starter
jhsteele3's Avatar
Thanks for the responses. So how do I go about matching my M12V to a baseplate for a router table? Sorry for the newbie questions but that is what I am.
john
post #5 of 7 (permalink) Old 01-31-2011, 09:40 PM
john
Hi John - There are some companies that have predrilled plates for the M12V (old style), Incra is one, for about $90.
Another option would be to get a blank and drill it yourself.
Easiest way to do this is to obtain a plate that will accept Porter Cable style guide bushings and use those in conjunction with a centering pin to locate the router and use the router sub-base plate for a template to drill the mounting holes.
John Schaben
jschaben is offline
post #6 of 7 (permalink) Old 02-01-2011, 10:50 AM Thread Starter
jhsteele3's Avatar
OK, which Porter Cable models use guide bushings?
post #7 of 7 (permalink) Old 02-01-2011, 11:05 AM
Hi John
Just about all PC's can use the guides..it's a default item for Porter Cable routers.
Hitachi M12V and Bosch 1619EVS routers LBrandt Table-mounted Routing 4 10-29-2011 12:44 PM
m12vc spring removal irexx Table-mounted Routing 2 05-19-2010 08:20 PM
Hitachi M12VC Router Plate kefjens Table-mounted Routing 1 01-02-2009 09:27 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 09:34 PM
M12V pricing/seller dtaylor15 General Routing 1 01-27-2006 11:41 PM
