Routing small pieces - Router Forums
post #1 of 4 (permalink) Old 02-03-2011, 01:58 PM Thread Starter
First Name: Howard
Default Routing small pieces
Hi, this is my first post. I am trying to make zero clearance inserts for my bandsaw. It measures 1 3/4" Dia. X 3/16 thick. Can anyone tell me the safest way to pattern rout something this small safely.
Howard
eb2621 is offline
post #2 of 4 (permalink) Old 02-03-2011, 04:12 PM
G’day Howard
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 02-03-2011, 04:34 PM
Hi
Hole saw
18 Piece Hole Saw Set
Howard
post #4 of 4 (permalink) Old 02-03-2011, 06:36 PM
Ralph Barker's Avatar
First Name: Ralph
A high-quality hole saw, with center drill removed, in a drill press would be my first choice, as well. Drill a staggered series of them in the material of choice to the desired depth, run masking tape over the cuts, and then resaw the board at that depth to release them. The masking tape keeps them from running off and hiding under the bench. Just be sure to clamp the board well, as it's going to want to spin.
Lesser-quality hole saws may not give you the clean edge you want. If all else fails, there are hole saws with carbide teeth, but they are quite expensive.
- Ralph
Ralph Barker is offline
Tearout routing small pieces of red oak the_nite_owl Table-mounted Routing 3 12-22-2009 07:40 AM
Routing small pieces using a handheld router geneengel General Routing 9 11-18-2009 01:50 AM
Routing small pieces Hamlin Jigs and Fixtures 11 10-25-2009 04:35 PM
Routing small pieces of timber colbra General Routing 11 07-01-2009 06:51 AM
routing small pieces zxxer12 General Routing 9 03-21-2005 03:40 PM
