Need to rout a rebate on a small frame - table or hand-held? - Router Forums
post #1 of 6 (permalink) Old 02-07-2011, 04:38 AM Thread Starter
cagenuts's Avatar
Country: South Africa
First Name: Hilton
Send a message via Skype™ to cagenuts
Question Need to rout a rebate on a small frame - table or hand-held?
Hi there
I'm making a bunch of frames (100m x 150mm x 20mm) and I need to rout a rebate on both sides to accommodate 3.2mm pegboard.
I don't see how I can secure this to rout hand-held so is my only option on the table? I think I would need to remove the fence and essentially rout free-hand.
Would a rebate bit with a 10mm rebate do the job?
I don't see how I could rout before assembly without a complicated stop system or is this rather the safer way to go. Remember the smallest piece will be 100mm long x 20mm thick.
What's the verdict on using a lock mitre bit to effectively make this frame? I need to get the frames together by Thursday and I only have two evenings left.
I know, I know but any pointers would be hugely appreciated.
Thanks in advance.
cagenuts is offline
post #2 of 6 (permalink) Old 02-07-2011, 07:15 AM
kp91's Avatar
First Name: Doug
I would do this on the router table. You can use the fence for this project.
Don't bother with a lock mitre bit, you can use a rabbet joint, just flip your stiles over and run the same rabbet on them and they will interlock with the rabbet you've put on the rails.
If you want a miter joint on the corners, you can glue up your frames with the miters first, then rout out the rabbet on the inside using a bearing piloted rabbet bit, just remember you'll either have to square the corners on the inside of the frame, or round the corners on the pegboard.
Hope this helps,
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 6 (permalink) Old 02-07-2011, 08:02 AM Thread Starter
cagenuts's Avatar
First Name: Hilton
Thanks Doug.
I was going to use the lock mitre bit to actually mitre the corners (trying to find a quick way of making them).
However if I were to rebate first, then cut at 45, then glue up, I wouldn't need to hack either the corners nor the pegboard right?
Thanks again.
cagenuts is offline
post #4 of 6 (permalink) Old 02-07-2011, 08:50 AM
Originally Posted by cagenuts View Post
Thanks Doug.
Thanks again.
Hi Hilton - Lock mitre bit isn't a good one to try to do the type of frames you are doing. When I do picture frames I put the rebate and profile(s) on the long stock then cut the miters. I reinforce the mitres with biscuits or splines which may be either hidden or displayed.
One reason a lock miter doesn't work well is all the joints are end grain.
John Schaben
jschaben is offline
post #5 of 6 (permalink) Old 02-08-2011, 07:45 PM
walowan's Avatar
First Name: Michael
If you are going to miter the corners I would cut the rebates first probably on a table saw....
walowan is offline
post #6 of 6 (permalink) Old 02-08-2011, 09:29 PM
kp91's Avatar
First Name: Doug
Thanks Doug.
Thanks again.
That's correct!
Good luck with your project!
1 John 1:9
Fredericksburg, VA
kp91 is online now
window frame rebate jdeb Portable Routing 7 07-04-2013 12:01 PM
Cutting very small pieces on table saw simplenik Tools and Woodworking 13 08-16-2007 06:10 PM
Small Router Table bobj3 Jigs and Fixtures 48 07-01-2007 11:22 PM
Small Router Table bobj3 Show N' Tell 2 06-05-2007 09:40 PM
Advice on buying router table jayhawk Table-mounted Routing 16 03-24-2005 11:46 AM
