Router set and dovetail jig advise - Router Forums
post #1 of 5 (permalink) Old 02-08-2011, 12:31 PM Thread Starter
First Name: Jay
Question Router set and dovetail jig advise
I want to replace an old B&D 7614 I have for about 20 years, for this I was thinking on a set like a DW 618 (B3 or PK), PC 895PK or B 1716EVSPK. I want to be able to make different type of projects and I think itíll be cheaper if I buy a set. Please correct me if I'm in the wrong direction.
Also looking for a dovetail jig and the templates to fit different brands of routers are kind of confusing, what goes with what?
If another set I didnít mention is a better option I would like to know about it, most of my equipment is DW and Bosch and I hear lots of good comments about PC, for that I include it on my search.
Since I keep my tools for long time I want to get one that last, I just retire and budget is a consideration.
Throughout my research I found out that all of them are excellent machines and also have their own bugs some fixed some others still there.
Iím also in the process on building a new table/fence to replace the one I made for the B&D years ago with a new one, more accurate and flexible, for that and reading all the related threads and I found very helpful, thanks. I welcome any ideas about the size and fence.
Iíll appreciate all the info I can get to make a decision on my new router set and a dovetail jig.
Thanks again for your help
el gaucho is offline
post #2 of 5 (permalink) Old 02-10-2011, 12:29 PM
Ralph Barker's Avatar
First Name: Ralph
For cutting dovetails, I use a pair of 1/2" PC 694 routers (2 1/4hp), one for the DT bit (tail cutting), and the other for the straight bit (pin cutting).
As to jigs, there is a wide variety of choices - either for use on the router table, or separate for use with the router handheld. The next breakdown of the separate jigs is for fixed spacing, or adjustable spacing. I use the fixed-spacing PC 4212 jig for machine cut DTs. If I want variable spacing, I simply hand-cut them. If I had space for a permanent dovetail station, I'd get the PC OmniJig.
The size and geometry of the bits and guide bushings need to match the geometry of the specific jig.
- Ralph
Ralph Barker is offline
post #3 of 5 (permalink) Old 02-11-2011, 07:59 AM
CharleyL's Avatar
First Name: Charley
I use a pair of DeWalt 618's to do blind dovetails. I bought my first one in their 3 base package deal and liked it so much that I bought a second 3 base set. I had to put big numbers on the top end to keep from mixing them up when I have different bits in them, but have been extremely happy with how well they are designed and how well they perform. I have 9 routers and the DW618's see the most use.
Charley
CharleyL is offline
post #4 of 5 (permalink) Old 02-11-2011, 03:17 PM Thread Starter
First Name: Jay
Thanks Ralph n Charley for your comment, I think you guys are provably tired of hearing the same question over n over again because all 3 are very close on features and performance.
But my main concern about the kits I mention is because reading lots of reviews and comments about them, I found some saying that the DW618 had problems losing the magnetic ring that controls the variable speed specially when is set upside down on a table; the B1716 sawdust in the switch and motor corrosion the same with PC895 some issues that I can’t recall now.
But then again looking at the date on some of the reviews I found out that many of them are few years old, 4 or more.
Obviously there is no “perfect” tool but in many cases those issues were corrected in newer versions and I was wondering if anyone knew something about that.
I like the dovetail jig PC4216 just because comes with the 4215 plate and almost the same price of the 4212; Do I need to get something else to be able to use it with those sets besides what is already supplied with them?
Thanks again
post #5 of 5 (permalink) Old 02-11-2011, 03:21 PM
TwoSkies57's Avatar
Hello Jay and welcome to the community....
with the 4216, you've pretty much got the whole package! All ya need is a router (preferably 2, one for pins, one for tails..this just makes things a whole lot easier, but not necessary) and a means by which to secure the jig to your work surface.
A bit of a learning curve, but nothing you can't handles and you're ready to go....
Skipper the Penguin
TwoSkies57 is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
