Using a router as a jointer - Router Forums
post #1 of 10 (permalink) Old 02-09-2011, 05:56 AM Thread Starter
First Name: Steve
Default Using a router as a jointer
I attempted to join a couple of 1x8's by using my router straight bit and had problems. I offset the outfeed part of the fence about about 1/16 and everything looked good. When I placed the boards together they have gaps at each end as if the middle of the boards are a little wider than the ends?? Any advice?
1100stx is offline
post #2 of 10 (permalink) Old 02-09-2011, 06:03 AM
Gene Howe's Avatar
First Name: Gene
One or both boards could have been bowed.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 10 (permalink) Old 02-09-2011, 06:09 AM
Cassandra's Avatar
First Name: Cassandra
Hi Steve:
Welcome to the Router Forums!
My experience with router table jointing is that if one doesn't properly line up the outfeed fence, one either gets the problem you described or the opposite (where there is a gap in the middle of the board.) It's very important to make sure that outfeed fence is in line with the furthest point of the bit's cutting circle. In other words, the outfeed fence must be tangential to the cutting edge's travel.
Cassandra
Carpe diem, quam minimum credula postero
http://www.panoramio.com/user/5924351
Cassandra is offline
post #4 of 10 (permalink) Old 02-09-2011, 06:12 AM
Jack Wilson's Avatar
First Name: Jack
How long, and how straight, (and sturdy), is the fence you are using? Also how long are the boards? An 8' board on a 2' fence will probably not yield, good results.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #5 of 10 (permalink) Old 02-09-2011, 09:06 AM
Honored Member
First Name: pat
Can be done, but only with attention to detail.
Quillman is offline
post #6 of 10 (permalink) Old 02-09-2011, 10:40 AM Thread Starter
First Name: Steve
Not too, not too and not too. It's a small ryobi table but the boards are only 24" long. May be time for a table upgrade.
1100stx is offline
post #7 of 10 (permalink) Old 02-09-2011, 10:41 AM Thread Starter
First Name: Steve
Tghanks
1100stx is offline
post #8 of 10 (permalink) Old 02-09-2011, 10:43 AM Thread Starter
First Name: Steve
Sorry, Thanks
1100stx is offline
post #9 of 10 (permalink) Old 02-09-2011, 10:44 AM Thread Starter
First Name: Steve
They make it look so easy on the web videos.
1100stx is offline
post #10 of 10 (permalink) Old 02-10-2011, 02:43 AM
gav
Country: Croatia
First Name: Gavin
I had the exact same problem yesterday with some looong stock on my tiny table. If only I had a 1.5 meter straight edge, i'd just use a flush trim bit.
Today I must try to solve the problem without spending money. Oh joy.
As a side note. Never buy pauwlonia wood. Everything I read about it made it sound pretty decent. Turns out it's slightly harder than balsa wood !!
gav is offline
Router as jointer? fishlore Table-mounted Routing 27 01-27-2010 03:15 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
