craftsman router quits - Router Forums
post #1 of 3 (permalink) Old 02-09-2011, 09:52 AM Thread Starter
First Name: rich
Default craftsman router quits
I read an article on the forum that described my problem exactly. I use mine exactly the same way. Upside down in a router table, where the switch is left on and the router table switch turns the router on. When I switched it to a plunge router it quit. I followed the instructions given on the forum and removed the switch and cleaned it. It still didn't work. So I removed the switch again, and carefully took it apart. I found clumps of sawdust, and the points were burnt. I used and old diamond deb nail file and filed the points flat, installed it and that solved the problem and run again. I ordered another switch right away.
Try it . it works.
claudia is offline
post #2 of 3 (permalink) Old 02-09-2011, 07:14 PM
G’day Rich
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 3 (permalink) Old 02-10-2011, 03:58 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
Craftsman router won't start wwkibler General Routing 12 12-23-2017 06:14 AM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
Craftsman Router Not Working Properly cosmokramer General Routing 13 10-15-2009 06:28 AM
