Collet stuck on router - Router Forums
post #1 of 7 (permalink) Old 02-11-2011, 06:10 PM Thread Starter
First Name: Graeme
Angry Collet stuck on router
Does anyone have any tips on how to free up a jammed collet on a PC router? Brute strength isn't working
OldBritBulldog is offline
post #2 of 7 (permalink) Old 02-11-2011, 07:14 PM
First Name: Steve
Send a message via AIM to Nailbender5
you might try heating the collet up and then try removing the bit. Just dont OVER heat it .
Steve
Nailbender5 is offline
post #3 of 7 (permalink) Old 02-11-2011, 07:23 PM
G'day Graeme
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 7 (permalink) Old 02-11-2011, 08:44 PM
kp91's Avatar
First Name: Doug
Is the collet stuck on the router, or is it just stuck on the bit? Chances are the bit was bottomed out in the router and raised a burr.
If the collet is stuck in the router, one trick you can try is to remove the motor from the base, and place one flat of the collet against a solid surface (workbench, vise, etc) and give the other side of the collet a 'tap' with hammer. You don't want to hit it too hard as to deform the collet, you just want to jar things a little bit. Sometimes a bit of percussive maintenance can free stuck threads.
If it is just a bit stuck in the collet, you remove the collet from the router, push the bit in as far as you can and file off the burr. Or, spend $12 on a new collet...
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #5 of 7 (permalink) Old 02-11-2011, 10:53 PM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #6 of 7 (permalink) Old 02-12-2011, 03:05 PM
The Warthog's Avatar
First Name: Roger
I would spray a little WD-40 or similar lubricant into the threads, and then try the tap with a hammer that Doug suggested. If your router is the type that uses two wrenches to tighten the collet, try setting the wrenches so they are close together, then squeeze the wrenches. A bit of help from a vise may help here.
Don't use heat and lubricant on the same day.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #7 of 7 (permalink) Old 02-18-2011, 12:39 PM
kp91's Avatar
First Name: Doug
Graeme,
did you get it out?
1 John 1:9
Fredericksburg, VA
kp91 is offline
replacing collet on Bosch router SanderW General Routing 15 03-31-2019 02:58 PM
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
Router Collet Extension RJM60 Table-mounted Routing 5 09-18-2010 02:30 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
