Fein Rt-1800 - Router Forums
 3Likes
post #1 of 12 (permalink) Old 02-13-2011, 03:03 PM Thread Starter
Default Fein Rt-1800
Hello all, new to your group. My name is Correy and I make custom woodwork like most of all you. I have had the 1800 in the table for 10 years now. The collet has worn till the bit will creep and slip. But I am unable to find a replacement for an otherwise fine Fein. I heard the DW625 is modeled after it. Any thoughts, leads , or fixes??? Other wise the baby will have to out with the bath water......
BTW custom replacement so far is $700. They also offered spraying a carbide spray that will increase the I.D. by .01", said it would be a cure all. They make CNC collets.
They also offered that a flat spray chroming would do the trick of increasing the I.D..
Really sad to see this great tool fade out.
Correy
Correy Smith is offline
post #2 of 12 (permalink) Old 02-13-2011, 04:27 PM
Correy
Hi Correy - Welcome to the forum
Sorry to hear about your collet problem. I'm unable to help but find it hard to believe that a "premier" company like Fein doesn't provide support. Makes me think twice about thinking of commiting a signifacant amount of money with them.
John Schaben
jschaben is offline
post #3 of 12 (permalink) Old 02-14-2011, 11:48 AM Thread Starter
Other than customer support, lacking as much as parts, They made a great router.
At Fein CPO, I was told a PC collet would "9 out of 10" times would be a direct replacement.....
This is a bit vague..... since the RT-1800 remains the same and the "X" model PC collet should be the same why would it only work 9 of 10 times????????
Hoping for help from a forum member in identifying which PC collet may work. I have the PC 2.1/4 hp plunge. The collet has the "C" clip that retains the clloet in the capture nut. So I do not believe that this would work. Does anyone know if there is a 1/2" collet made by PC that snaps in to a capture ring from the back of the collet nut same as the Fein?? Is the collet the same for the 3.25 hp PC as the smaller models?
Someone said try the DW625 collet. Thoughts?
Many Thanks,Correy
post #4 of 12 (permalink) Old 02-14-2011, 03:34 PM
Ralph Barker's Avatar
First Name: Ralph
If you can accurately measure the O.D. and thread pitch of the receiver, we might be able to compare notes.
- Ralph
Ralph Barker is offline
post #5 of 12 (permalink) Old 02-14-2011, 03:56 PM
Phil P's Avatar
First Name: Phil
Fein USA sold the RT-1800, but the model was never sold in Europe as far as I'm aware. If you look closely at the router you'll see that a very similar router has been sold under the names Trend T-9, Metabo OF-1612/OFE-1812 and Felisatti TP246(E)/R346ECV. At one time versions of this router were also sold by Holz-Her as well. The actual manufacturer of all these routers is Felisatti in Italy who have an American importer, ABN Marketing Ltd. They currently list the R346 on their web site, so that might be a good starting point. Failing that I'd suggest contacting Trend Routing Technology in the US to see if they can confirm availability of collets through them. They are very knowledgeable on the subject and the UK HQ should be able to provide an answer if the US subsidiary can't
Good Luck
Phil
jj777746 likes this.
Phil P is offline
post #6 of 12 (permalink) Old 02-14-2011, 04:47 PM Thread Starter
Thanks Phil, those are some really good leads. I will trace them down tomorrow when things open up.
I have also heard today at the dewalt service center here that B&D made the router for Fein. An Amazon search showed the collet for the DW625 looking very similar.
Also I found the White Side Quick Change chucks That fit the Dewalt 625 /Elu. Hoping that that might be an option as well. Anyone use these??
Thanks for the help!!
Correy
Sorry, I guess I'm still too new to this forum to post urls.... Had to edit them out.
post #7 of 12 (permalink) Old 10-02-2013, 04:37 PM
First Name: Michael
Correy
Any luck finding a replacement? I'm in a similar situation. I need a 3/8" collet for my FEIN RT-1800.
mikeumr is offline
post #8 of 12 (permalink) Old 10-02-2013, 08:18 PM
First Name: Phillip
One very simple tactic you might try is to go to the home improvement stores where a series of router brand will be on display. Bring your router. See if any of their collets fit your machine. If so, purchase it on amazon. I'm not familiar with many different brands, so I don't know if this is even a reasonable approach. I wish you luck.
To change the world, change your mind.
phillipdanbury is offline
post #9 of 12 (permalink) Old 10-03-2013, 12:46 AM
Semipro's Avatar
First Name: John_*
Phil
You might check here they will custom make collets
Elaire Corporation - Custom Collets
Semipro is online now
post #10 of 12 (permalink) Old 10-03-2013, 08:26 AM
There is danger in just finding a collet/nut that will screw onto your router. Variables like the cone angle can be a difference of 1/2 which leads to terrible vibration and destroyed bearings. My suggestion is you first check musclechuck.com to see if the updated interchange list includes your router. If not then contact Mark at Elaire Corp. in Ohio. Mark builds precision collet replacements for very reasonable prices.
Legacy Ornamental Mill 1800 - $2700 (Lowell) dutchman 46 The Bargain Bin 12 01-30-2015 07:13 AM
Broke Down and Bought A New Fein Multimaster Larry Strawson Tool Reviews 41 03-08-2014 11:31 AM
Fein Multimaster look alike istracpsboss Tools and Woodworking 33 05-07-2011 07:26 AM
Fein RT1800 Router sarge Table-mounted Routing 2 09-18-2010 11:36 AM
