Ryobi RE-600 Bearings - Router Forums
post #1 of 8 (permalink) Old 02-15-2011, 08:47 AM Thread Starter
Default Ryobi RE-600 Bearings
Has anyone taken a RE-600 apart to replace the bearings? My router, after 21 years of very dependable work, has started to protest with noisy bearings. I'd like to replace them before having a catastrophic failure. I removed the 4 retaining screws but I cannot get the bottom casting removed from the plastic case. I suspect it is a press fit, but before mounting it into my hydraulic press I'm wondering if there are any other screws holding it together.
jimmiler is offline
post #2 of 8 (permalink) Old 02-15-2011, 09:12 AM
Hi Jim
You may want to check out the link below, I'm sure you will get the info you need.
Tool Repair Help - eReplacementParts.com Power Tool Repair Forum
post #3 of 8 (permalink) Old 02-15-2011, 11:24 AM Thread Starter
Didn't find anything about the RE-600 there.
jimmiler is offline
post #4 of 8 (permalink) Old 02-15-2011, 11:50 AM
Hi
Just post your question and you will get some feed back.
post #5 of 8 (permalink) Old 02-15-2011, 04:29 PM
G’day
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #6 of 8 (permalink) Old 02-16-2011, 07:37 AM Thread Starter
G'day to you too mate.
jimmiler is offline
post #7 of 8 (permalink) Old 02-16-2011, 03:26 PM Thread Starter
Well, I did it, I got my router apart and replaced the noisy bearing. As I suspected, it just took a gentle persuasion from my hydraulic press to remove the motor from the bottom extrusion. The lower bearing was just fine, but the upper bearing sounded like it had sand inside. My local bearing supplier had a replacement bearing and I successfully put everything back together. The router works like new.
jimmiler is offline
post #8 of 8 (permalink) Old 06-08-2015, 12:19 AM
Hi, I actually just disassembled the same. (Ryobi RE601 -110V version of the RE 600)
There is a cable harness between the lower and upper part of the housing. I found no other way, then marking and cutting them. They will have to be joind beack later.
I found no "press fittted" things.
You will need two different bearing puller for the lower (biger) and the upper bearing (smaller) to pull off the shaft. I had to buy one on ebay for 26 pounds.
If you want pictures, or further info, my email is: szocsger at g m ail dot c o m
I hope that helps!
I am actually stuck at finding the right bearing replacement for these ones.
Can enyone help in this?
The trick is that these bearings should have rubber sealing (against fine dust) but high speed rating and preferebly no greater tolerance (looseness of the bearing) than standard at the same time. (not below 23000 rpm)
Thanks, Greg.
Greg777 is offline
Ryobi R 600. superchief Portable Routing 8 11-16-2014 11:18 AM
Guide bearings istracpsboss Router Bits - Types and Usage 30 04-25-2010 03:47 PM
How are the bearings in your router mike black General Routing 8 04-12-2010 10:03 PM
Roller edge guide for Ryobi RE 600 reid heilig Portable Routing 7 04-16-2009 06:09 PM
