Port Cable 891 router - Router Forums
post #1 of 6 (permalink) Old 02-15-2011, 11:25 AM Thread Starter
First Name: Randy
Default Port Cable 891 router
Hello,
I want to set up a router table. I am looking at the Porter Cable 891. I am also wondering if a "lift system" for the table is worth the money. Any feedback
Thanks, Randy
Rabbet is offline
post #2 of 6 (permalink) Old 02-15-2011, 04:28 PM
G’day Randy
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 02-15-2011, 06:12 PM
kp91's Avatar
First Name: Doug
Randy,
I've had good luck with my 890 routers.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 6 (permalink) Old 02-16-2011, 11:27 AM
Ralph Barker's Avatar
First Name: Ralph
I, too, have had good service from PC routers. But, some of them are only a few decades old, so it may be too early to tell.
My suggestion, however, is to size the router by the work you plan to do on the table. If, for example, you plan to do raised panels using large-diameter bits, a 3 1/4hp 7518 may be more appropriate. In that case, you may also want to spring for a lift. Having a (good) lift is otherwise a matter of convenience and the condition of your back. (Lifting a heavy router and plate from the table at arm's length can be a pain. Literally.)
- Ralph
Ralph Barker is offline
post #5 of 6 (permalink) Old 02-16-2011, 11:50 AM
Hi Randy
Many of the newer PC routers come with a lift built in, so to say you don't need to buy a lift for them, and yes it's worth the money to have a lift in the router table..
Just a note if you are going to spend 200.oo for a router I will suggest you take a hard look at the Craftsman 2 1/4 HP Pro.it comes with 3 bases (plunge,standard base, D-Handle) and all the neat items built in on all of them ..VS,soft start,Lift kit,Lights, etc.all in a nice case..looks likes a PC right..more bang for your buck..
I will say I got the two I have on Sale from Sears for 89.oo ea.
in the combo kit..and others members of the forum as well.
Amazon.com: Porter-Cable 0891 2-1/4 HP GripVac Router: Home Improvement
Technical Details
* Soft-starting, 12 Amp motor features full-time electronic feedback that maintains motor speed through the toughest applications
* variable-speed control feature (10,000 - 23,000 rpm) enables bit speed to be optimized for changing applications
* Release the motor, adjust height, and clamp the motor from above the router table with 3/16-inch hex socket (sold separately) or model # 75301 kit
* Dual-position switch allows user to cut power while maintaining control of the router
* Spindle lock feature allows for single wrench bit changes; Durable latch lever enables quick and simple coarse depth adjustments and motor release for transition between bas
Originally Posted by Rabbet View Post
Hello,
Thanks, Randy
post #6 of 6 (permalink) Old 02-16-2011, 01:38 PM
Bargains Finder
First Name: Tommy
I have the 890 as well and it works great in a lift and has power enough to do raised panels with ease.I picked up one recently at HD for $53 as it was a display model and they are clearancing them out at HD.
Tommyt654 is offline
Problem with Porter Cable 892 router the_nite_owl Tools and Woodworking 6 03-06-2011 09:31 PM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
