Router 1/4" to 1/2" collet needed - Router Forums
post #1 of 9 (permalink) Old 02-16-2011, 12:09 PM Thread Starter
First Name: Curt
Question Router 1/4" to 1/2" collet needed
Hi, obviously I'm new. I believe someone (Mark ??) was trying to connect with me, but I had a popup blocker on & I couldn't get back to him. Opp's!
My issue is with a Craftsman router model #315.175341. What I need is to find some way to use the existing 1/4" collet & adapt to a 1/2". I've looked around to see if something is available, but found nothing. Understand that I may be "search challenged"!
Any input would be great!! In advance; thanx C2 (Curt)
curtcich is offline
post #2 of 9 (permalink) Old 02-16-2011, 03:58 PM
I have a Craftsman 320.17542 router that came with two collets, 1/4" & 1/2". I don't know if these collets will fit your router or not, but they are interchangeable with my Ryobi RE-600 router. Perhaps you could simply switch collets.
jimmiler is offline
post #3 of 9 (permalink) Old 02-16-2011, 06:33 PM
Hi Jim
That would be nice but the collets will Not switch out, the error comes into play with the size of the hole in the router armature, it will only let a 1/4" shaft bits sit in the hole..
The one below is used to get the bit deeper or higher ..
post #4 of 9 (permalink) Old 02-16-2011, 07:18 PM
G’day Curt
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #5 of 9 (permalink) Old 02-17-2011, 01:01 AM
Country: India
try to ask a expert
madywatson is offline
post #6 of 9 (permalink) Old 02-17-2011, 01:56 AM
xplorx4's Avatar
First Name: Jerry
Greetings Curt and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #7 of 9 (permalink) Old 02-17-2011, 10:26 AM
BigJimAK's Avatar
Be careful when considering mixing and matching collets. as there's a lot more to them than first appears.
In addition to the threads you've got the length, diameter, taper and relief to consider.
When it comes to spinning a carbide steel cutter at 8k to 30k rpms in the vicinity of my body, I'm not an experimenter. Your mileage may vary.
BigJimAK is offline
post #8 of 9 (permalink) Old 03-22-2011, 09:51 AM Thread Starter
First Name: Curt
Hello Router Forum Folks;
Curt here, & thanx for all responses. My appologies for taking so long to reply, but I got sidetracked! I did read all replies, & came to the conclusion that I'm not knowlegeable (sp?) enough to go up against the physics of large pieces of carbide nested on bigger pieces of steel. My router is a fixed speed as well. My problem was that I purchased some new bits that have 1/2" shanks. In my excitement to try them out, I didn't even think of any consequences as to what might happen when forcing their use in my router. Since then, I have purchased a new router, that has the two bases, AND a set of two collets, as well as variable speed. After becoming a little more learned, this is the way to go. The two new bits are: a lock miter bit, & a couple of quadra cut bits-all of which are arger diameters than I had previously used. My readings have told me that these bits are better used @ slower speeds, both for safety and results of cutting. Again- thanx to all who replied to help me out. It is nice to have such good advices to "wake" me up!! Curt
curtcich is offline
post #9 of 9 (permalink) Old 03-23-2011, 07:48 PM
My first post here...
Anyway...just for those who follow...MLCS sells a 1/4 by 1/2 collet adapter for $4.00 postpaid as this is written. I had to order one last week after mistakenly ordering a 1/4 inch shank bit, instead of the 1/2 inch that I had intended.
Works perfectly and the price was right.
Sorry, local BS won't let me post a URL...maybe you can figure it out from the following:
http://www.mlcswoodworking.com/order..._ball_bearings
Very satisfied customer here...otherwise no relationship with them...
Henro is offline
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Adapt 1/4" router collet to 1/2" bit brian129 Router Bits - Types and Usage 22 02-13-2013 07:21 PM
Craftsman Quickrout 1/2" collet adapter lwbox CNC Routing 7 05-01-2011 09:56 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Where buy 1/2" collet DeWalt 621? charleyb General Routing 5 10-07-2009 09:37 PM
