Router Speed - Router Forums
post #1 of 7 (permalink) Old 02-24-2011, 07:50 AM Thread Starter
Default Router Speed
I have a 2.5 Hp variable speed router. What speed would I use to work on 1 inch hard woods (oak).
windrider is offline
post #2 of 7 (permalink) Old 02-24-2011, 09:40 AM
MikeMa's Avatar
It really depends on the router bit size. For your average round over bit, running it full speed will not be an issue. If you are doing a raised panel wing bit, you will need to run the router at a slow speed.
MikeMa is offline
post #3 of 7 (permalink) Old 02-24-2011, 10:22 AM
You can google "router bit speed charts" and many recommended speed charts show up.
Generally the smaller the bit the faster you can spin, larger the bit the slower but I've found it advantageous to use these recommended max speeds as a starting point and adjusting the speed for my own feed rate and the wood being routed.
While your feed rate should be reasonable it should not be much faster or slower than your "natural" rate.
Don't try to feed faster/slower to accomodate the speed of the router, slow down/speed up the router to accomodate your feed rate. I would not, however, exceed the recommended speeds for bit size per the charts.
Your oak, for instance, might burn when using your feed rate and recommended spin, slow down the spin a little until the burning stops at your feed rate.(better for the bit, too, less heat) This assumes a fairly constant feed rate on your part, hesitations and dull bits will burn pretty much at any speed. Too slow a spin might cause more blowout/tearout, chatters and a harder feed.
As long as the spin rate produces a quality cut at your feed rate go with it.
TomE is offline
post #4 of 7 (permalink) Old 02-24-2011, 09:42 PM
Glen L's Avatar
First Name: Glen
Another worthy mention is to do light cuts instead of trying to complete the whole cut in one pass, it's much easier on the router and bit.
Cheers
Glen
Glen L is offline
post #5 of 7 (permalink) Old 02-25-2011, 07:43 AM
The Warthog's Avatar
First Name: Roger
It's always good to take some scrap and experiment to see what works best.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #6 of 7 (permalink) Old 02-26-2011, 10:52 PM
First Name: Colin
Default Setting Router Speeds
I always recommend to set the router speed at the lowest speed and to take off a small amount of wood until you start to get the "feel" of how the router, the bit and the wood are working together. By raising the speed and taking a bit more wood off, you will quickly learn what setting combinations work best.
Collett is offline
post #7 of 7 (permalink) Old 02-27-2011, 03:16 AM
derek willis's Avatar
First Name: Derek
Recommended speeds are printed on the router cutter shanks.
Derek.
Derek
derek willis is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Modulated speed router problem. seanburns General Routing 6 08-19-2013 08:20 AM
Router Speed Control Switch fieldsd General Routing 6 07-05-2009 04:36 PM
Router Speed Guide CanuckGal Starting Off 9 12-25-2008 04:52 PM
