Hitachi TR12 sticking last ~2 inches - Router Forums
post #1 of 10 (permalink) Old 02-27-2011, 09:07 PM Thread Starter
First Name: Hugh
Default Hitachi TR12 sticking last ~2 inches
Hi everybody - Great forum, already learned a lot... Here's another one that you guys may have dealt with before... I was given a TR12 that seems in good condition except it sticks when plunging all the way down. The posts were looking clean but bone dry so I added a bit of Triflow, it helps a bit but still not quite usable. I'm speculating that the router was stored in its box for many years with the plunge lock set, and this may have warped that particular post (?)
I thought I'd ask for suggestions before I start taking it apart... any advice?
Thanks!
H.
TheU is offline
post #2 of 10 (permalink) Old 02-28-2011, 06:09 AM
allthunbs's Avatar
First Name: Ron
Thanks!
H.
Hi Hugh:
I have the M12V and to take _it_ off the posts is real simple. There is a threaded rod with two spin nuts to stop the router from sliding off the posts. Just unthread these two spin nuts and carefully lift it off the columns. When you take it apart, there will be a little brass stub that will fall out. Don't lose it and don't forget to put it back. That's your plunge lock. I take mine apart on a cafeteria serving tray to be sure I don't loose that little part. It's only 1/4" dia x 1/4" long. Wash thoroughly the columns scouring them with one of those nylon kitchen scouring pads so it is perfectly clean and dry. A light waxing with paste wax or some Boeshield T9 on the column to finish the job. Before reassembling you should also check to be sure the column is true. My tools are stored in a slightly heated workshop so I'm doing this frequently.
Yours' might be just as simple. Besides depending on your environment, it may be a routine maintenance job. Worth learning at the beginning rather than in the middle of an operation and ruin a workpiece.
Allthunbs
allthunbs is offline
post #3 of 10 (permalink) Old 02-28-2011, 09:20 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
All routers require the occasional strip and clean, this link takes you to an exploded diagram and parts list for the TR12.
Hitachi TR12 parts breakdown on ToolPartsDirect.com
Harry
harrysin is offline
post #4 of 10 (permalink) Old 02-28-2011, 08:36 PM Thread Starter
First Name: Hugh
Thank you both, I'll give it a shot!
H.
TheU is offline
post #5 of 10 (permalink) Old 03-06-2011, 09:14 PM Thread Starter
First Name: Hugh
It was indeed a piece of cake. Found a scratch from an old injury, sanded down, done. Thanks again!
H.
TheU is offline
post #6 of 10 (permalink) Old 03-06-2011, 11:51 PM
G’day Hugh
Belated welcome to the router forum.
Thank you for joining us
Glad to see we were able to help
Sydney, Australia
jw2170 is offline
post #7 of 10 (permalink) Old 12-24-2012, 10:21 AM
Marco's Avatar
Does anyone have information on cleaning the plunge posts for the Craftsman 2hp softstart?
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #8 of 10 (permalink) Old 12-24-2012, 10:33 AM
125 to 145 lbs. psi of air from your air hose will do the job just fine..
post #9 of 10 (permalink) Old 12-24-2012, 12:06 PM
Marco's Avatar
Thank you Bob and Merry Christmas to you and yours.
Marco is offline
post #10 of 10 (permalink) Old 12-24-2012, 12:12 PM
Thank you Jim and Merry Christmas to you and yours
hitachi tr12 collet bakerscookin General Routing 3 01-15-2011 06:46 PM
Cordless Drill Hitachi DB3DL Manual Manuals Hitachi Manuals 0 12-16-2010 12:18 AM
Hitachi TR12 help telecarver1 General Routing 4 09-25-2009 05:55 AM
Hitachi TR12 for table? Dave_Willemain Table-mounted Routing 3 05-22-2008 10:54 AM
