Angles of router - Router Forums
post #1 of 13 (permalink) Old 03-03-2011, 09:35 PM Thread Starter
First Name: Greg
Default Angles of router
Hi,
I am so new here that this will be my first question to ask this forum.
I know with my table saw I can make nice angle cuts, but I have a problem as stated below:
I just got my Porter Cable router moutner on router table and stand and
I am trying to figure how I can make some some angles using my router
instead of just straight line cuts.
Any suggestions?
Greg-Lynn Haven
Greg-Lynn Haven is offline
post #2 of 13 (permalink) Old 03-03-2011, 10:19 PM
Glen L's Avatar
First Name: Glen
Welcome to the forums Greg.
Why do want to make angle cuts with a router?
Cheer
Glen
Glen L is offline
post #3 of 13 (permalink) Old 03-04-2011, 12:47 AM
BigJimAK's Avatar
Greg,
The low-budget approach is to put the wood on a wedge to tilt it while supporting it, if the angle isn't too severe.
The expensive way is to buy one of these for $230 Woodhaven - Woodworking Tools, Supply & Equipment or, if you have a trim router and get their last one in stock for $100 Woodhaven - Woodworking Tools, Supply & Equipment
Otherwise, some here have built their own angle mounts, but it was an involved process.
Maybe others will think of an inexpensive solution I have missed?
BigJimAK is offline
post #4 of 13 (permalink) Old 03-04-2011, 08:46 AM
Amazon.com: Bosch PR005 Tilt Base for Bosch Colt Palm Routers: Home Improvement
Don't for get if you route wood on a angle you are trapping the wood, not to smart on the router table, the router table is not a table saw..one cutting point unlike the table saw..
They do make many,many router bits with the angles on the bit..
post #5 of 13 (permalink) Old 03-04-2011, 10:44 AM
BigJimAK's Avatar
Thanks, Bob... I forgot about that one!
BigJimAK is offline
post #6 of 13 (permalink) Old 03-04-2011, 07:46 PM
G'day Greg
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #7 of 13 (permalink) Old 03-04-2011, 11:59 PM
wm_crash's Avatar
First Name: Cosmin
Have a look at this:
YouTube - Stave drum - router jig
It can be made out of MDF,t-track, and some clamps.
cheers,
wm_crash, the friendly hooligan
wm_crash is offline
post #8 of 13 (permalink) Old 03-05-2011, 09:58 AM
Hi Cosmin
Have a look at this, it's a set it and forget setup ,one pull or push and the job is done and no jig needed .
http://www.routerforums.com/attachme...hread-0553.jpg
post #9 of 13 (permalink) Old 03-05-2011, 01:38 PM
Phil P's Avatar
First Name: Phil
There's always the really expensive way, the Virutex FR317S router
Phil P is offline
post #10 of 13 (permalink) Old 03-06-2011, 08:13 AM
First Name: Mark
I have shown this on here before but this is what I came up with. It's a router table that can change from 0 to 90 degree's. I use it a lot but I mostly use it for routing groves for splines at any angle. I hope to come up with some plans for it in the next month or so.
Name:	router t 1.jpg
Name:	router t 2.jpg
Name:	router t 3.jpg
Name:	router t 4.jpg
Name:	router t 7.jpg
Mark Sternberg is offline
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
Which Router To Get Etc? Gaia General Routing 10 02-24-2010 04:52 PM
