8529 Porter Cable won't run...seeking suggestions. - Router Forums
 2Likes
post #1 of 29 (permalink) Old 03-04-2011, 07:55 AM Thread Starter
Default 8529 Porter Cable won't run...seeking suggestions.
8529 purchased 2004 has low hours, installed in Rockler table, recently went to use and would not start, isolated from table switch, opened case and checked router on/off switch confirming open line, make line function. Speed control components have some evidence of moisture/oil as some dust has locally accumulated at these components. Might anyone offer some guidance on debug options? Am thinking switch, speed control and thermal fuse are in the path to energize motor. Thanks in advance for any suggestions/recommendations. I do not live near a PC service center.
HobbyJim is offline
post #2 of 29 (permalink) Old 03-04-2011, 09:00 AM
Guest
First Name: Regis
Jim,
Can you blow it out with compressed air, or, if not, with a hair drier?
Regis
48394 is offline
post #3 of 29 (permalink) Old 03-04-2011, 09:18 AM
First Name: del
I don't quite get this . you say opened case and checked router on/off switch confirming open line, make line function. Open line ?? are you useing a ohm meter?? Use a volt meter and make sure that you are getting 110volt thro the line cord. Now measure across switch on one side you should have 110volt on the other nothing tell you push switch on now their should be 110volt's on both side's ?? Should run. if nothing. Than i belive you are done. Posible the control module ? I been around repair for over 50 yr's . I would take it to a repair shop. Voltage measurement's are a must. to see where you loose it . good luck
del schisler
port st. lucie, florida
del schisler is offline
post #4 of 29 (permalink) Old 03-04-2011, 09:30 AM
Hi
A simple check, jump the switch, if it runs you found the error,if not put the parts back in place and take it to a motor repair shop, you need to have the right tools to find the error.
post #5 of 29 (permalink) Old 03-04-2011, 09:51 AM Thread Starter
Thanks for the clarity on checking the switch. In fact, I did use a VOM and checked without first, then with 110V. In both cases the switch function was validated and voltage is transferred. I will try blowing some air across the control board but do not expect that to correct the issue. Ideally I would like to isolate/bypass the control. Thanks again.
HobbyJim is offline
post #6 of 29 (permalink) Old 03-04-2011, 10:48 AM
BigJimAK's Avatar
Jim,
When making the "air shot", go beyond the control board. Taker a shot through the top and bottom air vents to clean out the windings, then remove and check the brushes. If they aren't making contact, it won't run.
Jim
BigJimAK is offline
post #7 of 29 (permalink) Old 03-04-2011, 03:48 PM
The speed control crapped out on mine and the part is no longer available.
Porter Cable 8529 TYPE 1 parts breakdown on ToolPartsDirect.com see Ref #163
Ended up bypassing the control and just leaving the adjustment wheel in. No soft start or variable control but it works.
Found it to be a fairly common problem for these particular routers.
TomE is offline
post #8 of 29 (permalink) Old 03-04-2011, 06:04 PM Thread Starter
Hi Tom -
Thanks for sharing your solution.
By chance do you recall when you bypass the speed control, which wires were sliced together? Did you slice the powercord white input with the red winding lead?
Any details you could share would be greatly appreciated.
I too discovered at lunch that the replacement module item 163 (P/N 906889) thru toolpartsdirect is no longer available...perhaps I wouldn't have liked the price either.
Alao, completely cleaning the unit out with compressed air was unsuccessful.
Thanks again,
Jim
HobbyJim is offline
post #9 of 29 (permalink) Old 03-04-2011, 06:15 PM
Hi
Why not just sale the OLD PC on eBay for parts and be done with it and pickup a NEW 2 HP Craftsman combo kit for 80.oo bucks..about the same price as a gas tank full of gas now days, looks like the new PC routers right, but much better with all the neat items ,all in one kit.
Sears: Online department store featuring appliances, tools, fitness equipment and more
You just may break out even up.after the sale on eBay.,but you end up with a brand new router in the deal .
http://www.google.com/products/catal...d=0CFsQ8wIwAA#
post #10 of 29 (permalink) Old 03-04-2011, 08:39 PM
Hi Tom -
No, don't recall which wire went where but I believe that I poked around with a multimeter and found the swich legs and how power was fed to the motor(neutral and hot). Then just switched the hot leg and led neutral to the motor, any ground is preserved of course. (unit is not plugged in at any time while testing)
The wider blade on the plug is neutral side so you can check where the neutral comes into the router and the other blade is the hot.
I definitly recall doing a "test run" with simple twisted splices before tidying up for reassembly. (be careful)
Bob's solution doesn't sound half bad either.
TomE is offline
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Porter Cable 8529 Dr.Zook General Routing 2 05-14-2013 07:33 PM
porter cable 4216 jig Da Mrs. Jigs and Fixtures 8 12-14-2011 10:19 AM
Sold: Porter Cable 8529 plunge router Tommyt654 Woodworking Classifieds 5 01-22-2010 02:39 PM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
