Inset a Trap Door Latch - Router Forums
post #1 of 5 (permalink) Old 03-05-2011, 09:42 PM Thread Starter
First Name: Mark
Default Inset a Trap Door Latch
I have to install several 3"x 3.5" trap door latches to a plywood wall. How do I make a jig and what bit should I use?
mbeiderwieden is offline
post #2 of 5 (permalink) Old 03-05-2011, 09:56 PM
Hi Mark
A picture is worth a 1000 words.
post #3 of 5 (permalink) Old 03-05-2011, 10:13 PM
xplorx4's Avatar
First Name: Jerry
Greetings Mark and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 5 (permalink) Old 03-05-2011, 11:26 PM
G'day Mark
Welcome to the router forum.
Sydney, Australia
jw2170 is offline
post #5 of 5 (permalink) Old 03-06-2011, 03:34 AM
derek willis's Avatar
First Name: Derek
Make a jig out of 1/2" mdf with a cut-out in the centre the exact size of your fitting, using a short top bearing mortise cutter, set jig into position and rout out the centre to a depth sufficient to accomodate the fitment, clean out the corners and there you are.
Picture attached, shows cutter to use being the left hand one.
Derek
Picture 26.jpg (109.2 KB)
Derek
derek willis is offline
Setting up LV drawer lock bits for inset drawers Cayuga Kid Router Bits - Types and Usage 6 10-01-2008 08:13 AM
inset Bookcase Shadrac Show N' Tell 4 05-21-2008 10:19 AM
