Looking for a router lift - Router Forums
post #1 of 13 (permalink) Old 03-06-2011, 04:39 PM Thread Starter
First Name: Aaron
Default Looking for a router lift
Just got my new Kreg precision router table and fence set up and now am looking for a router lift to get that PC7518 above the table for bit changes. Can anyone recommend a good lift?
ac615 is offline
post #2 of 13 (permalink) Old 03-06-2011, 08:19 PM
Ralph Barker's Avatar
First Name: Ralph
I use a BenchDog Pro lift, and like it. The plate, however, is integral to the lift, and it might not fit the opening in your Kreg table.
- Ralph
Ralph Barker is offline
post #3 of 13 (permalink) Old 03-08-2011, 06:24 AM Thread Starter
First Name: Aaron
Thanks Ralph.
ac615 is offline
post #4 of 13 (permalink) Old 03-08-2011, 08:09 AM
First Name: Kerry
I just went through this exercise. I have three Kreg tables and I'm building a fourth. After lots of research and touchy-feely, I ended up with the Jessem Mast R Lift II.
Couple of things to keep in mind:
The Bench Dog plates won't fit the Kreg's table cutout. They are a different size.
Kreg has a lift (PRL-V2 made by Woodpeckers) that fits and accommodates Kreg's mounting system (the holes line up).
Jessem's plates (careful: they make a smaller Bench Dog version) drop into the Kreg table perfectly but the two corner mounting holes don't line up with Kreg's under table mounting system. Not a deal breaker as the combination of the lift and the PC 7518's weight is substantial enough it isn't going anywhere. The Kreg's leveling system still works with the Jessem. I just ran a bunch stile & rails through no sweat.
I spent a fair amount of time with the WP PRL-V2 and didn't care for it. The quick lift action was spotty at best. Sometimes it would engage, sometimes you had wiggle around and try and find the release point. The thumbwheel to me was tedious. Too much thumbing to get adjusted which also was dependent on where you were in the 3/4” travel limit. You would have to get the quick lift wrench out again to make an adjustment if you were topped out up or down. It was also definitely harder going up with the thumbwheel… even with the brake all the way loosened. Which by the way stuck up past the surface of the table even only slightly loosened. In order to get the set screw below the surface the brake was full on. The unit was beefy enough and well machined… just didn’t execute as well. Others love it.
I would look at the Sidewinder version of this lift. I believe your not limited to 3/4" travel wherever you stop with the quicklift and the crank is just easier than the thumbwheel. Probably would have been my choice, but I stopped looking when I came across the Jessem Mast R lift II. It is extremely substantial. Works with the PC 7518 (or most routers) right out of the box. The cranking & locking action is silky smooth. It only takes a few moments to crank all the way up or down.
So for me... it came down to the Jessem Mast R Lift II or the Woodpeckers Sidewinder. I think you can't go wrong with either one. I might give the Sidewinder a try later on one of my Kreg tables. The Mast R Lift II is going in the new built table.
Good luck with your search. :-)
2bigfeet is offline
post #5 of 13 (permalink) Old 03-12-2011, 10:55 AM
edh
edh's Avatar
First Name: Ed
Good info 2BF,,thanks.
I am looking for a lift as well and have narrowed my selection to the Jessem or the Kreg. What was the final key that swung you to the Jessem?
I am inclined towards the Jessem but can't let go of the Kreg because of their quick release.
Ed
edh is offline
post #6 of 13 (permalink) Old 03-12-2011, 09:06 PM
First Name: Kerry
Ed
To be clear, the Woodpeckers PRL-V2 that I played with was the Kreg branded version (its blue and the mounting holes line up with the Kreg table). Once I worked with the quick lift action for a while it did seem to get easier to deal with. What turned me off of that particular lift was the thumb wheel and the 3/4" limit in one direction or the other. If your topped out or bottomed out, your either thumbing or getting out the wrench. My arthritic thumbs couldn't deal. I believe the Sidewinder version of this lift does not have the travel limitations.
I only went with the Jessem on a lark because I found a great price on it... before I found a retailer with the Sidewinder in stock. I'm sure I'd be just as happy had I stumbled on the Sidewinder first. That said, I'm totally happy with the Mast R Lift II. Like butter.
2bigfeet is offline
post #7 of 13 (permalink) Old 03-12-2011, 09:16 PM
First Name: Kerry
Just to add...
Having spent a fair amount of time playing with the quick-lift action, I can't say I miss not having it on the Jessem. It literally just takes moments to go all the way up, or all the way down. Which by the way... when does that happen? Also, the Porter Cable 7518 clears the table for bit changes.
2bigfeet is offline
post #8 of 13 (permalink) Old 04-02-2011, 09:25 AM Thread Starter
First Name: Aaron
Purchased this Jessem Lift and got it installed in the Kreg table. Works great. Thank for the tip!
ac615 is offline
post #9 of 13 (permalink) Old 04-02-2011, 03:17 PM
I have never been a fan of lifts since most people use combo kit routers which perform the same functions for a lot less money. The PC 7518 is one router where a lift is a good idea. I have my 7518 mounted to one of the discontinued Rockler large style aluminum mounting plates. Reducing set up time is always nice. Thank you for sharing your thoughts on this Kerry.
post #10 of 13 (permalink) Old 04-02-2011, 07:56 PM
First Name: Kerry
Good luck with your new setup Aaron. My Jessem lift is getting used almost daily. I'm really enjoying it.
2bigfeet is offline
Router lift for Freud FT3000vce? Tuthmose Table-mounted Routing 12 12-10-2010 10:35 PM
Hello DPugmire New Member Introductions 5 11-08-2010 06:29 AM
Shop made router lift Noob Table-mounted Routing 7 01-19-2010 01:02 AM
Router Lift for the Skil 8125? MajMayAL Table-mounted Routing 3 11-28-2009 02:56 AM
