How to fasten template - Router Forums
post #1 of 3 (permalink) Old 03-06-2011, 05:57 PM Thread Starter
keenecowboy's Avatar
First Name: Martin
Default How to fasten template
What are the members suggestions to fasten a template to project?
I have a circle template that I want to use to cut a circle, using the flush trim bit.
The template is 10 inches, I do not want to use a nail or screw to hold in place.
keenecowboy is offline
post #2 of 3 (permalink) Old 03-06-2011, 06:49 PM
HI Martin
I will suggest PIN (23g) nails, they are so small you can't see the holes and if you do a drop of water on the nail holes ,they will disappear just like magic, that's the neat thing about pin nails ,they push the stock to one side and the water will pop it right back..I don't suggest using tape it likes to let the stock move just a little bit..and the glue will seal the wood. ( botchs at stain time )
http://www.amazon.com/NuMax-SP123-Ga...9462824&sr=1-5
post #3 of 3 (permalink) Old 03-06-2011, 07:28 PM
Honored Member
First Name: pat
I'd clamp & rout, reclamp and rout.
Many? Then I'd fixture and use toggles.
A zillion? Then Vacuum hold down.
Quillman is offline
Template thickness question atmguru222 Guide Bushings and Templates 4 02-27-2011 08:20 PM
How to make a template accurate? Steve Blackdog Guide Bushings and Templates 4 01-02-2011 03:44 PM
My first template - a TS throat plate sofasurfer Guide Bushings and Templates 25 03-13-2010 12:25 PM
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 08:23 AM
