router set-up - Router Forums
post #1 of 6 (permalink) Old 03-07-2011, 08:24 AM Thread Starter
Default router set-up
making raised panel doors with freud 97-100 bits having problem matching stile&rail set-up are there set -up blocks for these bits
spider41 is offline
post #2 of 6 (permalink) Old 03-07-2011, 07:59 PM
G’day
Welcome to the router forum.
Thank you for joining us
Most folks use a test piece to set up the bits and keep the test piece as a set up block.
Sydney, Australia
jw2170 is offline
post #3 of 6 (permalink) Old 03-08-2011, 03:08 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi
You could try one of these Ezset For Freud Bits-Sommerfeld's Tools For Wood
Cheers
Peter
istracpsboss is offline
post #4 of 6 (permalink) Old 03-08-2011, 03:44 AM
derek willis's Avatar
First Name: Derek
I have a set of Freud raised panel and stile bits and I have made a lot of doors with them, when I first started, I used some odd pieces of rail and stile and tried a few times until I got it right, I kept one of each that fitted and have used them ever since to make an accurate set up at first try.
Picture 001.jpg (261.5 KB)
Derek
derek willis is offline
post #5 of 6 (permalink) Old 03-08-2011, 09:11 AM
Hi
"tried a few times until I got it right" that's the big error with most door makers,if your stock is not the same thickest ever time, you can make your own setup blocks but it's not the same the norm. , it can be off by 1/32" or less and parts will not fit right.
If the bits are setup right for the stock you are going to use it will come out right every time...with almost no sanding the joints or the panel..
The real key is NOT to move the router up or down when you switch out the bits..and use a match set of bits..
http://www.sommerfeldtools.com/somme...lans/ezset.pdf
http://www.sommerfeldtools.com/somme...log/page03.pdf
http://www.sommerfeldtools.com/somme...log/page27.pdf
http://www.sommerfeldtools.com/somme...log/page29.pdf
post #6 of 6 (permalink) Old 03-09-2011, 03:29 AM
First Name: Derek
I have no problem with timber thickness, as the norm for cabinet doors is 20mm and that is what I stick to, the only thing I forgot to mention, is that, one must make sure the plunge lock is on before routing or the set-up will be lost after a while.
Derek.
Derek
Solid Brass Router Inlay Set Mike Wingate Guide Bushings and Templates 31 02-05-2011 05:24 PM
Best heavy duty router for use in a table set up paulcomi Tools and Woodworking 6 05-11-2006 07:58 AM
