Router bit for 1/2 inch baltic birch - Router Forums
post #1 of 10 (permalink) Old 03-10-2011, 11:33 AM Thread Starter
First Name: Kelly
Default Router bit for 1/2 inch baltic birch
Does such a bit exist? I want it to cut dadoes in the baltic birch. Get a dado blade for table saw instead?
thanks
Kr
Kelly Rittgers is offline
post #2 of 10 (permalink) Old 03-10-2011, 12:51 PM
I use a Freud "undersized" 1/2" plywood bit and it works great. Measure your plywood with calipers and then do the math on which bit you need.
Tempest is offline
post #3 of 10 (permalink) Old 03-10-2011, 01:48 PM
walowan's Avatar
First Name: Michael
unless it's more than 20 or so inches from the edge of a piece of wood I just use a dado blade in my table saw...
walowan is offline
post #4 of 10 (permalink) Old 03-10-2011, 03:05 PM Thread Starter
First Name: Kelly
I don't have a dado blade. Maybe this is a signal I should get one.
KR
post #5 of 10 (permalink) Old 03-10-2011, 03:11 PM
KR
Hi Kelly - How long of a dado do you have and how many? Several ways of getting there; adjustable dado jig comes to mind. Lately the 1/2" ply I've been getting calipers out to a tad over 7/16". I've been routing 7/16" wide dados and then shaving the edge of the mating piece on the router table. May not work very well for a large project though.
John Schaben
jschaben is offline
post #6 of 10 (permalink) Old 03-10-2011, 09:15 PM
wcpalmer's Avatar
Send a message via Yahoo to wcpalmer
Before investing in Dado blade for yout table saw, check the saw for available shaft lengths. Some contractor saws do not have a shaft long enough to install the whole dado set on.
Chck the jig section on the forum here, there is several jigs for using your router to cut dead accurate dados.
Bill
wcpalmer is offline
post #7 of 10 (permalink) Old 03-10-2011, 10:37 PM
The Warthog's Avatar
First Name: Roger
Just use a flat bottomed straight router bit the width of your plywood or slightly less. If needed, you can widen the dado to the right size by applying masking tape to the edge of the router that runs along your straight edge and running along the cut again. the masking tape will move the router over just a little to widen the cut to the correct size..
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #8 of 10 (permalink) Old 03-10-2011, 10:46 PM
Why a dado blades when a router bit will do the job right.
4 pc 1/2" SH Dado Plywood Straight Router Bit Set - eBay (item 130496211249 end time Mar-17-11 19:09:44 PDT)
post #9 of 10 (permalink) Old 03-10-2011, 10:56 PM Thread Starter
First Name: Kelly
13.50 is a lot of money for 4 router bits.
post #10 of 10 (permalink) Old 03-10-2011, 11:06 PM
Router Bit Sets - Plywood Dado Value Sets
Correct way to install a router bit Goldglv Router Bits - Types and Usage 22 04-07-2010 09:46 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
New here burlboy New Member Introductions 9 01-15-2009 11:53 AM
