repair craftsman router - Router Forums
post #1 of 12 (permalink) Old 03-11-2011, 06:09 AM Thread Starter
First Name: N/apaul g j
Default repair craftsman router
I have a problem with my Craftsman router either the wiring or motor, in any case I cannot remove the housing to examine it. Made several attempts to remove housing with no success?
paul g j is offline
post #2 of 12 (permalink) Old 03-11-2011, 06:31 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
post #3 of 12 (permalink) Old 03-11-2011, 07:17 PM
G'day Paul
Welcome to the router forum.
Sydney, Australia
jw2170 is offline
post #4 of 12 (permalink) Old 04-29-2011, 04:08 PM
Hi I have the same prob did u find a answer? My lock switch seems to be holding the
casing on.
meatman147 is offline
post #5 of 12 (permalink) Old 04-29-2011, 04:25 PM
casing on.
Hi Rick - Craftsman markets several dozen routers, model number would help.
John Schaben
jschaben is offline
post #6 of 12 (permalink) Old 04-30-2011, 01:09 PM
dutchman 46's Avatar
First Name: Howard
You may find that there is dust,and wood chips that are wedged in the base, and housing. Try blowing out any dust, dirt from around the machine, and try to adjust the base as You go. Some routers collect dirt in the worst places.
John 3:16
dutchman 46 is offline
post #7 of 12 (permalink) Old 07-13-2011, 03:07 PM
First Name: stuart
seems to be a really faulty brand buddy
lots of problems raised about this brand
not seen them in england
hope u get sorted
good luck
stuart
england
stuartwatson is offline
post #8 of 12 (permalink) Old 07-13-2011, 09:29 PM
Stuart, Sears sells Craftsman brand in the US and Canada and there are more of these routers in the market than any other brand. They are built by different companies so you might end up with a Ryobi, Bosch, PC... depends on the model.
Some of the routers have ball bearings between the motor and base; it is best to take these for service by someone familiar with them. (They are a real pain to reassemble)
If you need help with a Craftsman router the first step is to copy down the model number. Many of the manuals are posted in the reference section of the forums. Some models are similar enough to others that the methods are identical for repairs. It helps if you can post a photo of the model you are having trouble with; it saves everyone time checking for the right information.
post #9 of 12 (permalink) Old 07-18-2011, 12:56 PM
First Name: stuart
thanks bud
help appreciatted
stuart
post #10 of 12 (permalink) Old 08-24-2011, 09:35 PM
First Name: Kevin
Default help
Can you tell me who makes mine I bought it with out the removable cord and can't find one anywhere. The router is a craftsman professional 12.5 amp model number is 320.28084 any help would be greatly appreciated.
kdq100 is offline
Base Plate for Craftsman Router Steve1946 Craftsman 12 12-04-2014 06:22 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Craftsman Router with Wolfcraft® Folding Router Table WoodCrazy Table-mounted Routing 2 01-05-2010 01:12 AM
Craftsman Router Not Working Properly cosmokramer General Routing 13 10-15-2009 06:28 AM
