Freud FT2000E Problem - Router Forums
post #1 of 6 (permalink) Old 03-13-2011, 01:07 PM Thread Starter
First Name: Danny
Default Freud FT2000E Problem
This is my first time on this site which I found trying to get information on my Freud 3 1/4 HP router. I do some woodworking, mainly wood-turning as a hobby and inherited this router. Today I set it up to use for the first time and when I switched it on it runs about 1-3 seconds and stops. The router has not been used in about 8 years.
Any suggestions on a solution to the problem will be much appreciated.
Danny
DannyL is offline
post #2 of 6 (permalink) Old 03-13-2011, 01:27 PM
Hi Danny
I have done this a time or two to get a old one to work..
Chuck up a 1/4" dowel pin or a 1/4" bolt without a head or threads in your drill than chuck it up in your router, blow out the router with air and spin the router motor for two mins. or so and than take the drill off and try it ..with luck it will run again.
Danny
post #3 of 6 (permalink) Old 03-15-2011, 03:10 AM
G'day Danny
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 6 (permalink) Old 03-15-2011, 09:06 AM Thread Starter
First Name: Danny
Hi Danny
I tried the dowel and drill with compressed air. It increased the run time to maybe 4-5 seconds but turning the switch on after that reduces the run time each occurrence until the router won't run. It will repeat the cycle after sitting for a period.
Thanks for the recommendation.
DannyL is offline
post #5 of 6 (permalink) Old 03-15-2011, 08:21 PM
First Name: Pete
Maybe pull the brushes and clean them off.
psjr56 is offline
post #6 of 6 (permalink) Old 02-06-2012, 11:06 AM
First Name: Ed
Danny
Hi Danny;
The fact that the unit is running is a good sign. But the fact that it falters in cycles usually points to a thermal over load.. It may be that something in the router has rusted or corroded causing a heat build up that stops the router. If you have the knowledge take it apart and give it a though cleaning in any areas that would cause this to occur. Also give the switch a good look over and blow out if you can. Otherwise I would take it to an authorized repair facility to have them look at it.
In God and sharp tools I trust!
routered is offline
Instruction Manual Freud FT2000E warmbruster New Member Introductions 15 09-11-2015 12:48 PM
How to remove Freud FT2000e plunge springs? GeneSimm7 General Routing 7 11-27-2010 11:03 AM
freud ft2000e bolo New Member Introductions 7 09-14-2009 06:02 PM
Freud FT2000e for table router KonaJohn Table-mounted Routing 7 05-13-2009 02:57 AM
Freud FT2000E problem toolman_206 General Routing 9 11-28-2007 07:31 PM
