cutting/chopping semicircles on ends of wood - Router Forums
post #1 of 5 (permalink) Old 03-16-2011, 04:26 AM Thread Starter
First Name: john
Default cutting/chopping semicircles on ends of wood
Hello Router people.
I would like to know the most economical way of acquiring a semi circle shape on the end of a 50mm wide piece of wood.
A chisel would do I know but when your disabled and want at least 20 or more done it gets back aching etc.
I did get the idea that a jig could be made up on a swivel/pivot arm so the end of the wood could lay against a tool that will shave/sand the end of my piece of wood squarely.
Has anyone an idea as to what I can do or indicate to me I'm on the right lines with my idea.
It would be nice to know and being new to these forums I'd like to make it clear I don't go for stupid and inane remarks.. which I'm sure the moderator on here will agree with me.
Thank you in advance.
Mr Shedman42 is offline
post #2 of 5 (permalink) Old 03-16-2011, 05:00 AM
derek willis's Avatar
First Name: Derek
John,
Make a jig and cut with a router using a bit the size of your required emblem.
Derek.
Derek
derek willis is offline
post #3 of 5 (permalink) Old 03-16-2011, 05:12 AM
G'day John
Welcome to the router forum.
Thank you for joining us
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 03-16-2011, 08:37 AM
walowan's Avatar
First Name: Michael
A hole saw in a drill press might be your fastest, safest method.
walowan is offline
post #5 of 5 (permalink) Old 03-16-2011, 09:01 AM
gav
Country: Croatia
First Name: Gavin
Judging by the different answers, there seems to be some confusion as to exactly what you are trying to achieve.
So I made a drawing of the 4 possibilities I can think of.
Choose one of them and then I think you'll get a lot more help with what you want to do.
1 and 2 can be achieved using a router and the correct profile bit.
3 and 4 could be done with a jigsaw, bandsaw, scrollsaw, or a router with a straight bit and a trammel/ circle cutting jig.
gav is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
Thinning out paint to soak in wood StormStrikes The Finishing Touch 3 08-18-2010 10:59 PM
Wood splits and cyanoacrylate crquack Woodturning and Lathes 3 07-01-2010 07:28 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
