Cross grain - Router Forums
post #1 of 8 (permalink) Old 03-17-2011, 07:35 PM Thread Starter
Lakelad's Avatar
First Name: Gary
Default Cross grain
Is there a way to prevent tear out when routing across the grain. I am doing dados on the ends of some poplar and it is across the grain. Thus far a lot of tear out. Also the wood being routed is only a distance of one inch. What is the best way to move it across the blade. I have narrowed the fence on my router table as much as I dare, but it still isn't narrow enough. Maybe some sort of auxilliary fence? I'm new to routing and appreciate all of your help.
Gary
Lakelad is offline
post #2 of 8 (permalink) Old 03-17-2011, 08:32 PM
Hi Gary,
Are you using a back up block behind the poplar. I believe this prevents tear out.
Sydney, Australia
jw2170 is offline
post #3 of 8 (permalink) Old 03-17-2011, 10:23 PM Thread Starter
Lakelad's Avatar
First Name: Gary
James I was not and hearing it makes me wonder why I didn't think about it. Thanks so much, I'll give it a try tomorrow.
Gary
Lakelad is offline
post #4 of 8 (permalink) Old 03-18-2011, 03:51 AM
gav
Country: Croatia
First Name: Gavin
Holding a piece that small in a screw clamp will give you more contact with the fence and save your fingers from potential damage.
gav is offline
post #5 of 8 (permalink) Old 03-18-2011, 04:28 AM
derek willis's Avatar
First Name: Derek
Clamp a false fence in place to narrow the gap.
Derek
derek willis is offline
post #6 of 8 (permalink) Old 03-18-2011, 09:20 AM
CharleyL's Avatar
First Name: Charley
Gary,
If you are doing all four edges of a panel you can do the cross grain cuts first. Then when you do the long grain cuts the damaged areas will be removed. If you are only doing cross grain cuts that will not be followed up by long grain cuts, then a backer is the best answer. It's also possible to make most of the cross grain cut without doing the ends and then carefully climb cut these end areas. This last method isn't recommended unless you find that it's the only way. Then do multiple very shallow cuts until the correct depth is reached.
Charley
CharleyL is online now
post #7 of 8 (permalink) Old 03-18-2011, 11:46 AM
MikeMa's Avatar
Another technique I have used for dados, rabbets, and tenons that go across grain is the piece I am working on I will leave a little wide. After I completed the crosscut, I will rip the piece down to size, typically taking out all the tear out. This isn't optimal in every case, but works well when it can be done.
MikeMa is offline
post #8 of 8 (permalink) Old 03-22-2011, 07:52 PM Thread Starter
Lakelad's Avatar
First Name: Gary
My thanks to everyone for your suggestions. Still learning to use the router and you have all been a great help.
Gary
Lakelad is offline
Ski question os smoothing end grain, bit, speed, etc TanOak Portable Routing 4 11-07-2010 09:03 AM
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 08:32 PM
Staining end grain rstermer The Finishing Touch 11 02-21-2009 08:22 AM
Best wood/ grain hiding technique for jewelry box top rstermer The Finishing Touch 3 05-03-2008 11:57 AM
Routing end grain Pop_pop1 Table-mounted Routing 8 09-22-2004 12:24 PM
