I need to router out the middle of plexiglass - Router Forums
post #1 of 4 (permalink) Old 03-18-2011, 11:29 PM Thread Starter
First Name: Tim
Smile I need to router out the middle of plexiglass
I'm wanting to router a 4"x4" piece of 1/4" thick piece of plexaglass, I want to cut a pattern out of the middle of the plexiglass.
How can I do this? I have a router and a small router table. What bit should I use? Can this be done?
Look at the picture, this is what I want to do. I did this one with a drill press, I think a router would be a better way.
Thank You,
Tim
Name:	Henbury 74.2g.JPG
easytim is offline
post #2 of 4 (permalink) Old 03-19-2011, 12:58 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Do you require a one off or many of the same Tim?
Harry
harrysin is offline
post #3 of 4 (permalink) Old 03-19-2011, 01:23 AM Thread Starter
First Name: Tim
Each piece of plexiglass is unique and is a one of a kind and and will need to be hand made
easytim is offline
post #4 of 4 (permalink) Old 03-19-2011, 01:35 AM
harrysin's Avatar
First Name: Harry
In that case Tim my suggestion would be a scroll saw whereby you drill a hole close to the outline, insert the blade through the hole, attach it in place and away you go following the line, finally sanding the edge followed by polishing. Whilst routing would lead to a much better surface finish, it's far more difficult even for an experienced routologist and very messy, the swarf covers the marked line constantly requiring clearing away as static makes it cling.
Harry
harrysin is offline
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
Router Recall (PC, SEARS, RYOBI) Birdflu General Routing 5 02-23-2012 10:01 PM
