7518 help needed - Router Forums
post #1 of 5 (permalink) Old 03-22-2011, 09:21 AM Thread Starter
First Name: Craig
Default 7518 help needed
I have a porter cable 7518 mounted in my router table and it seems that a sliver of wood got in to it and busted all the fins on the motors cooling fan. I have managed to take the router apart down to the large aluminum base and the shaft but I can not figure how to get the nut that hold the bit collet on the shaft taken off the shaft without damage to either. Has anybody had to do this that can throw some light on my problem?
CraigR is offline
post #2 of 5 (permalink) Old 03-22-2011, 10:12 AM Thread Starter
First Name: Craig
I figured this out myself so I thought I would post to let others know how. That nut is normal right handed threads so what I did was to put on a leather glove and hold the armature shaft with one hand then take a 1/2 impact gun with a socket and zip, the nut came right off with no damage to either.
CraigR is offline
post #3 of 5 (permalink) Old 03-22-2011, 06:56 PM
Jack Wilson's Avatar
First Name: Jack
That's the trick, have had to do it myself. Others here told me the method and I was skeptical, but it worked! How much will the fan set you back?
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #4 of 5 (permalink) Old 03-22-2011, 08:17 PM
01stairguy's Avatar
First Name: Ron
thanks for the imfo
01stairguy is offline
post #5 of 5 (permalink) Old 03-23-2011, 11:46 AM Thread Starter
First Name: Craig
Found it online for only $14 including shipping.
CraigR is offline
PC 7518 -> Lift Suggestions nwilliams Table-mounted Routing 22 01-05-2011 02:12 AM
looking for used prolift and PC 7518 dbarr15 Table-mounted Routing 0 10-13-2009 05:29 PM
Router selection help needed robdunstan Table-mounted Routing 19 02-14-2008 03:37 PM
Remote PC 7518 speed control mntbighker Table-mounted Routing 5 01-02-2008 10:43 PM
