Tearout making finger joints - Router Forums
post #1 of 8 (permalink) Old 03-22-2011, 07:16 PM Thread Starter
First Name: Ray
Default Tearout making finger joints
Tried making finger joints in low grade BC plywood and experienced a lot of tearout using an MLCS jig and a Freud 1/2" straight bit. Using a 2.25 hp Porter cable router. Has any one tried using a spiral bit for this purpose and if so what was the result? I was displeased with using a zero clearance plate with a Dado blade on the table saw.
Rb583 is offline
post #2 of 8 (permalink) Old 03-22-2011, 07:38 PM
walowan's Avatar
First Name: Michael
Low grade ply will make nasty joints of any kind....
walowan is offline
post #3 of 8 (permalink) Old 03-22-2011, 08:09 PM Thread Starter
First Name: Ray
They weren't too bad, was just hoping for something a little more presentable. I am going to try a spiral bit n see if it helps. Maybe I will use a 1/4 " n then a 1/2". I have 2 routers so I won't be changing setups. Will let you know if it works. Thanks
Rb583 is offline
post #4 of 8 (permalink) Old 03-23-2011, 03:55 AM
gav
Country: Croatia
First Name: Gavin
Were you using a backing board ?
I have a few ply magazine racks from Ikea that have industrial made box joints and they are pretty clean. It's only 4mm ply.
When ever I try with ply, it's a mess and I don't know why. I suspect that the quality and type of wood used in the ply has something to do with it.
I've been considering pre scoring the joints with a sharpy to see if that helps.
gav is offline
post #5 of 8 (permalink) Old 03-23-2011, 04:43 AM
Country: Germany
First Name: Titus
Use Double-Sided tape and put on not only a backing piece but also a sacrificial "fronting" piece. I use offcuts of 4mm ply.
You should end up with clean cuts.
Cum Catapultae Proscriptae Erunt Tum Soli Proscripti Catapultas Habebunt
Titus A Duxass is offline
post #6 of 8 (permalink) Old 03-23-2011, 05:00 AM
gav
Country: Croatia
First Name: Gavin
Good tip, I'll give it a go when I can get back in the workshop.
Cheers.
gav is offline
post #7 of 8 (permalink) Old 03-23-2011, 10:58 AM Thread Starter
First Name: Ray
I did notice that when I used soap on the straight bit prior to cuts there seemed to be a lot less binding and tearout. I will try the double sided tape idea sounds like it should work, especially given the tapes properties, thanks for the input. Like I said it is only Home Depot BC plywood but making finger joints I did not expect 20% tearout. I am new to the forum and appreciate all of the feedback.
Rb583 is offline
post #8 of 8 (permalink) Old 03-23-2011, 12:29 PM
walowan's Avatar
First Name: Michael
Baltic birch ply can make nice joints but cheap ply is mostly impossible
walowan is offline
finger joints Sig Gebhardt New Member Introductions 5 10-06-2010 03:25 AM
Fine Tapered Finger joints jn_capili New Member Introductions 8 01-14-2009 09:26 PM
Finger Joints J0B00 Jigs and Fixtures 18 08-24-2007 02:19 AM
finger joints ron dwyer Tools and Woodworking 3 11-28-2004 11:44 AM
