Hitachi M12V2 plunge lock problem to avoid - Router Forums
post #1 of 2 (permalink) Old 03-25-2011, 07:42 PM Thread Starter
First Name: Alan
Default Hitachi M12V2 plunge lock problem to avoid
I have a Hitachi M12V2 (the powerful, ugly, inexpensive one) with the plunge springs removed for router table use. To avoid problems, if you remove the base, make sure to remove the lock lever first.
I recently took the base off to cut out the "ears" that prevented raising and lowering a panel raising bit, though they interfered less than the M12V ones did. (Cutting off the M12V ears is shown and explained on the woodshopdemos.com site.) I cleaned the base carefully before reassembly to avoid getting any metal filings into the router itself. I noticed a rattle as I inverted it, of something loose inside. The plunge lock lever no longer functioned.
Here's what happened. The lock lever works by having a bolt (with left hand threads) push a little brass cylinder (#60 Lock Piece on the parts list) against one of the plunge rods. If you remove the base with the plunge rods, the little brass cylinder falls inside the router, and is a pain to get back out.
All you need to do to prevent this is to unscrew the screw holding on the lock lever, pull off the lever, and turn (clockwise) out the bolt. Tip the router to get out the little brass cylinder. Now you can safely remove the base and plunge rods without causing a big headache.
AlanWS is offline
post #2 of 2 (permalink) Old 03-25-2011, 07:57 PM
allthunbs's Avatar
First Name: Ron
Hi Alan:
THe M12V was built the same way. I take out the columns and let the cylinder fall out. I turn the router on its' side and insert the cylinder with a pair of tweezers before putting in the columns. Just an alternative method if someone needs it.
Allthunbs
allthunbs is offline
Router Hitachi M12V2 Manual Manuals Hitachi Manuals 0 12-16-2010 12:33 AM
Craftsman plunge router problem Edmarzo General Routing 2 07-21-2008 08:40 AM
Hitachi M12V2 - Fine Adjustment Problem mcelduff General Routing 3 03-07-2008 08:30 AM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 06:50 AM
PC 690 Plunge Base problem. NewMontanaWorkshop General Routing 11 09-27-2004 12:01 PM
